I have a vibration at 55-mph, car had been aligned; new tires; new tie rods; drove for a while and still vibrates but now at 60-65 mph... so i replaced the hub/bearing; ball joint; and the CV joint cause the passenger side was ripped and greaseless... all this on both sides. Now car is put back together... and there is this thumbing so i blocked the rear and jacked up the front, put the vehicle in drive... the left side moves freely but the right does not move, but when a little throttle is applied thumbing shakes the whole car.... not sure where to look ??
Any ideas would be greatly appreciated...
First thing I would get done would be wheel balance . Then check for sticking brake pads and free off if needed . If still having problems , check engine and transmission mounts for wear .
