Hi Everyone,
I have an 03 Grand Marquis. I had to remove the power steering pump as it was leaking, and in the process discovered the high pressure line to be leaking. Does anyone know how to remove the other end of the line that goes into the steering rack? I can barely see up in there. It is right below the oil filter. Someone mentioned needing a special tool? I've attached a picture for reference. This was made prior to 12/03. Thank you!!!
James
Discussion Starter #2
Ok. For everyone wondering I did get the line off. I discovered there is a 10mm bolt on the right hand corner which holds a plate. That plate holds both this line and the return line to the cooler to the rack. As soon as I removed that bolt, both lines came right off.
