When decelerating and approaching a stop the front end rattles From about 30mph down until about 10 mph. From 10-0, no rattle noticed. It actually shakes the pullout cup holder. I've heard that maybe balljoints or bushings. Big difference in repair costs. Any way to tell for sure?
Its very odd. It does do it upon braking, but then when I release the brake, and reapply, it doesn't occur if traveling less then 10 mph. I tried to roll slow with the brake applied, to see if I could feel the pads grab/not grab on the rotor (i have felt that before on my explorer and as such, replaced them) but could ot feel a thing. Someone mentioned a Sway Bar or its bushings to me yesterday. Hate to just start tearing it apart and replacing it all if I can same some time and money by isolating. Was thinking about lifting the front end, and doing the tire wiggle test, then try to wiggle the tie rod ends, and inspecting the pads.
Go on ebay and buy a front end kit. Its about 150 dollars. Best way to do it. Other than that I suspect it to be a balljoint if it comes from one side in particular and if you live in a rainy or snow area.
If it seems to be a uniformal sound coming from the center go inspect the swaybar and bushings. another thing you can do move the truck up and down to see where the news is coming from and add a lubricant on all the bushings one by one till you can isolate one. If that doesnt work do that to all the ball joints and lower/upper control arm bushings. until the noise stops the lube should stop it
