As " the fonz " states , need more info . Depending how much water and whether it was sucked into engine . Check oil level and see if water in sump . If so you will have to drain it , but may also caused engine to hydraulic .
It splashed over the motor front end came.up out of water truck died I tried to start it once with exhaust in water it wouldn't pulled it out air filter was soaked changed it it started and ran for 30 sec still turning over pretty good but won't fire.
Sent from my Motorola Electrify using AutoGuide.Com Free App
Hello,
I have an Ford Kuga diesel that there is a turbo problem on.
I almost immediately get the fault code P2263 after starting to drive.
They guy I bought it from got a diagnose from a mechanic where they said the turbo is shot. Reason was a vacuum problem...
The throttle body is kinda...
My diesel stalls when I put it in reverse but runs forward just fine. The transmission was rebuilt 15,000 miles ago and I don't seem to have any problems with it shifting though there is a slight lag between pressing on accelerator and the truck taking off. This started about the same time the...
So I was running on fumes and I needed fuel something terrible, so I stopped at the first place I saw fuel, the place was $2.45 a gallon for diesel and it was green and 5% biomass diesel fuel. I didn't notice my truck run any difference, how ever my fuel millage tanked from 20ish to 13. anyone...
i have tryied every thing to get the battery light to go out on my 99 f250 supperduty changed alt, light went out after hitting 2000 rpm , now wont go out ,not charging
I'm a tech and I have a 2004 6.0 no start 120k no codes
I traced it down to the lpop. I pull the cover off the lpop no oil is being pulled through picktube. no oil in pump. I found the regulator stuck open . this would cause it to not pull oil at all right? or would it still pull some oil ...
