if you can reach the line and adapter going into the radiator try and warm it up a bit with a small propane torch. Hold the line with vise grips and see if it'll break loose. Only enough pressure on the vise grips to hold it don't crimp the line
Alright, TY. I'll give it a whirl next time i'm off.if you can reach the line and adapter going into the radiator try and warm it up a bit with a small propane torch. Hold the line with vise grips and see if it'll break loose. Only enough pressure on the vise grips to hold it don't crimp the line
