Battery died on my fathers car, replaced battery and now experiencing multiple electrical issues.
Tried a battery reset, removed negative and left overnight, hooked back up. No change.
Symptoms.
Stuck in park - can depress solenoid switch under steering wheel to shift out of park
Have brake lights - swapped brake switch just to test, was not bad
No turn signals - when using turn signal, it activates a left or right high beam
no interior lights
DASH DISPLAYING
Flashing a code 53
Showing trunk open
TPMS showing fault
Radio works, hvac works
I've checked the central fuse box and fuse box under the hood. All check out.
I don't see any rodent damage, wires look to be in good shape.
Leaning toward a module failure of sorts, but hate to go on a goose chase.
Light research leads me to either a master light switch, clock spring, or turn signal stalk failure.
Would anyone be able to provide some insight towards these symptoms?
Symptoms.
no interior lights
DASH DISPLAYING
Flashing a code 53
Showing trunk open
TPMS showing fault
