·Just saying hello as being one of the first hope this forum gets going i have alot of questions.
yes, i believe they are direct bolt ons, however the gear ratios are slightly different, being the gt's gear ratio is made to match the 2.2 turbo's powerband and has beefier internals as well. if you are going that lengh, you might as well swap trannies too. i heard it's a lot more work than you think...Dan [Sac] said:Here's your first -
can I bolt a GT motor to a GL tranny? I thikn I also need to swap ECUs, wiring, halfshafts, some steering components, etc. BUT - are the trannies the same?
