I bought this beautiful car as a driver and it has a 350 CID Chevy engine. Right after I got it I started having charging problems. It has 3 gages bolted under the dash. Temp., Volt Meter, and Oil pressure. It had a one wire alternator with a external voltage regulator on it. I bought a 10S1 3 wire 63 amp alternator used primarily in the 70s and 80s with built in regulator. I can't find anyone local that knows anything about it and have been working on it for about 3 months and am no closer that when I started. It has a black wire and red wire coming from the starter plus the battery wire going to the starter. I've been on the computer looking for so long I look like a computer. When I find something and try it, it doesn't work out. I have a new volt meter, light switch, and ignition switch. (3 wires that says bat., ign., and sol.
I also have a new battery. If anyone knows where to put the wires, I can understand exactly what you are talking about, even the big words. I'm trying to make a deal now on a flathead engine to put back in it but want to get this one ruining good first. I don't have a charge light in in now, but if it is needed let me know and where it goes. I appreciate all answers and will try them all. Thanks.
