I need to buy a thermostat housing on an old flathead six
Mine cracked and need another one
The housing has a three bolt hole on the 6 cyl
Administrator
I've searched and searched with no luck. Plenty available for V8's none for 6. You might try contacting these guys Old Ford Parts at C&G Ford Parts. Tens of thousands in reproduction. they didn't list one of a 6 but might be able to point you in the right direction.
You can also try Car-Part.com--Used Auto Parts Market but I had no luck with the search feature.
Our moderator RS Logan should be on in the morning. He's from the UK and may know of a source there to order from.
Looks like this is what your after ?
The only one I found was sold out I'm afraid .
Yes that is it, Tha'ts what I need...that's the 3 hole thermo housing
