I replaced the control valve and now with wheels off the ground when I turn to the left it shakes a lot. to the point I have to shut off the car. It is also more difficult to move to the left and the pump makes a few noises and will squeak. Ford manual said to put transmission fluid in the power steering. I replaced the pump also. Does it still need transmission fluid or should I switch to power steering the new pump.
Everything was fine till I changed the control valve and put in transmission fluid instead of power steering fluid.
