If you can feather the pedal and it's better , COULD be accelerator pump in carb . If plug lead was bad it should have meant that cyl was not firing . Other leads could be breaking down under load . Some carbs have a filter in the carb which can choke up . Check and see if timing is advancing when revving up to see if dist. advance / retard is working
