41 - 43 of 43 Posts
You sure I said that ?
Yep, I am not the best at navigating around the forums, but if you go back to the first page of this issue, you can find it. With your experience, and I have read many posts that you have made, I kept checking to make sure that is what you said. I kept expecting someone to comment on it? You can verify to be sure. Just one Ford lover to another, with a different mother. Although I have owned a couple of cracked head every valve rusted oil leak every time vehicles. Thanks Terry
No problem . any help is welcome I think you may be commenting on various links / pictures in the posts which were copied from elsewhere to help the member and not attributable to me personally but from other sources as I have double checked my posts ? If #1 is wrong , it needs changed and should make a difference to the running (y) If I get a chance I will check it out again
41 - 43 of 43 Posts
