1 - 7 of 7 Posts
Hello everyone.
I have just come in to the possession of a 1974 Ford 4D Gran Torino.
Aside from the dead battery it starts up nicely.
As I proceeded to try and move it I quickly discovered I had no movement. So I check the parking brake. The pedal itself when applying pressure does not lock down, it only comes back up to position.
The brake release when pulled does not offer any tension what so ever.
-Suggestions?
Old Cars, Strong Hearts
Don't have any suggestions for you (sorry), but ... looks like a nice 1974 Gran Torino, otherwise ... congrats!
Cort > Old Cars, Strong Hearts
pigValve.paceMaker.cowValve | 1979 Caprice Classic (needs new owner)
"It happens every time" __ Linda Ronstadt __ 'When Will I Be Loved?'
Sounds like your cabling might have seized. If the shoes are locked in the drum, trying pushing it backwards, it might pop them, but you're more than likely going to have to dismantle the rear brakes to get it towed home.
Hopefully it will not come to that. I didn't have much time to mess with it the other day. I hope it is something I can disengage by myself with a little bit of work. I did try going in drive and reverse, it jumped like it wanted to move but the rear wheels just won't rotate. Would a parking brake do that? or could it be rust or the transmission?
As suggested , the cables may be seized and need releasing manually as a temporary measure .If the brake shoes inside the drum are also seized , rapping the back plate with a hammer often frees them off .
This sounds more like brakes, but if you want another check, jack and block the car, shift it into neutral, drop the drive shaft and rotate the output of the transmission.
1 - 7 of 7 Posts
