1 - 7 of 7 Posts
· Registered
Just recently got an 84 tempo with the 2.3 and a carb. Put plugs, wires, cap and rotor on it, checked the pcv valve and tried adjusting the choke which seems to have 2 rivets and one screw instead of 3 screws. It's got a stumble when starting out or if you blip the throttle. Also put a carb kit in it and cleaned all the jets, and the bowl. Good exhaust on it as well. It's got 16K miles on it. Can anyone help with this?
· Registered
Vacuum leak(s) can cause this. One item in particular I would look at would be the brake booster. Probably original, making it almost 40 years old.
Plug the vacuum hose supplying it to see...if the stumble goes away, then that's the problem; if it doesn't, then something else is.
Float level too low can also cause this.
· Super Moderator
Haven't done that yet, maybe a bit slow? Guess I need to borrow a timing light.
Possibly ignition timing retarded , this might / might not help you
· Registered
Discussion Starter · #6 ·
What throws me off is that if you hold it at a slightly high idle at the stop, it acts fine. Only when starting out from a low idle does the stumble show up. No shortage of power once rolling at all. Float level is correct, new accelerator pump as well as needle valve and seat and other new parts from the carb kit. I do need to get a distributor clamp wrench to see about tweaking the timing a degree or two though.
· Registered
My ‘86 had a similar problem, see post #6 in this thread,
Your EGR valve may be different than mine, my Tempo has the early fuel injection.
1 - 7 of 7 Posts
