I have a 1985 Lincoln Mark 7 with a 302, it is flooding out when gas is given at idle. The car will run for 8 minutes at idle, and then die for the day. I have replaced the throttle position sensor, the fuel regulator(which is not ajustable, but the original was), have had the 2 injectors checked and cleaned, and I can't figure out what else could be wrong. If you have any ideas that might help, please let me know.
Mark VII member
check you oxygen sensors you engine could be puting the wrong fuel to air mixture in there. also it could be the fuel return unit, i dont know how it could happen but myabe its cloged and fuel is unable to pass through smoothly.
