I just picked up a 1989 ford ranger has 2.9 motor with what says to be 4 speed with overdrive (5th gear marked on shifter as overdrive) It does not have reverse or overdrive so I am figuring the fork is damaged I think that is what it is called. will it hurt to drive in town where I wouldn't need 5th/overdrive I do know at 55mph in fourth I get 3000 rpm's found that out driving it home
Well, you're missing reverse and overdrive, there's no guarantee you won't contribute to the damage unless you figure out what's causing your issue. Also, what if you need to back up?
Plan on fixing it but only vehicle I have right now need to get back and fourth to work, I believe the fork is bad for the OD/reverse it is a Mazda M50D-R1 manual trans .
2 Participants
Charles Powell
