If you insist on dealing with a shop that, for whatever reason, you don't
trust, you will be doing both yourself and the shop a dis-service...
From the factory, the only provisions for adjustments are for front and rear
toe. If front caster/camber or rear camber is out of spec, some adjustment
can be gained trough the use of aftermarket kits. My experience shows that
these kits are neither cheap to purchase nor cheap to install.... but if I
see readings that may cause driveability issues or tire wear concerns, there
isn't much choice in the matter. I will not put myself into a position where
the customer can blame his worn tires on me.
As for the specs themselves.... it would be a little time consuming for my
to type them out (not to mention the opportunity for a typo) and my
conditiones of employment prohibit me from doing a cut and paste.... Your
local library will often have service manuals that you can copy or any
alignment shopthat you can bring yourself to trust will either have the
specs programmed into their alignment rack or have one of the aftermarket
specs listings tha some fornt end part manufacturers have available.
HTH
"Wound Up" <
[email protected]> wrote in message
news:
[email protected]
> Hello
> Can anyone tell me what the alignment specs are (toe, caster, camber,
> cross camber) for a 1989 Ford Tempo, FWD, 2.3?
> Thanks in advance. I don't trust this shop, and want to be armed with
> this info before I go in.
> Wound Up
