· Registered
I keep having to replace the rear wheel bearings in our festiva every 3 to 4 months.None of the dealers can give me an answer as everything i am doing is by the book.Can some one please help.
Thanks :fraz:
· Registered
Are you tightening them to the right tension? Are you packing the bearings properly(forcing the grease through the bearing)? If you're doing everything right, maybe they're just crap bearings- try another brand if possible. What do the bearings look like when you take them out?
· Registered
The bearings are corectly packed with grease and tensioned corectly.There is no warning when they are about to go.You are driving when you suddenly start to hear a noise coming from the rear wheels then the brakes grab.When you jack up the car the whole drum assembly is lose and when you take it off the bearings have completly colasped.I have tried at least two different brands of bearings with the same result.
Thanks for your reply :wnc:
