Tom has PMed me with a reply but I prefer to discuss the diagnosis of the
circuit on the NG so that we can all benefit from the process and offer
input. He replied that none of the windows worked from any of the switch
positions..
One of the big considerations in checking the fuses is the possibility of a
missing fuse. This has caught many of us with our pants down... tech and
DIYer alike. On this 94 Ex, fuse F2-11 (that's fuse number 11 in the
underdash fuse panel) should be a 30 amp. If the fuse is present and tests
good with a test light... a voltmeter is not a good choice for this
diagnosis.... we move on to the drivers door switch.
Since all of the windows are involved and there is no indication that they
have failed one by one, we should be fairly safe in assuming that this will
be a simple power or ground concern. I prefer to use a home built
"extension" cord so that I can connect my test equipment directly to the
battery posts.... mine is 30 feet long and cost less than $10 to
fabricate.......
Remove the drivers door switch and locate the light blue with black trace
wire (hopefully Ford didn't decide to swap colours on us). With the key in
Accessory or Run position and the lead on the test light to ground, the lamp
should light. Move the test lamp lead to battery+ feed and probe the black
wire. The lamp should light.
If one or both of these fails, remembering that the vehicle is 12 years old,
the most likely place we will find a concern is inside the bellows between
the drivers A pillar and the drivers door.
A good quality repair may be a little difficult since we wont want our
splice in the area that bends...
HTH
"tom" <
[email protected]> wrote in message
news:
[email protected]
>I have a 1994 Explorer and all the power windows stopped working. I looked
>at all the fuses and none are blown. Is there a relay someplace that
>could have stopped working?
> Any suggestions.
> Thanks
