I was installing an aftermarket radio to replace my old aftermarket radio that is over 10 years old. Connected the wires and everything was looking good, except I had no audio. So I pulled the radio out and a flash of sparks happened and no more radio. The fuses weren’t blown and everything looked okay. What could be the problem?
Apart from a fuse supplying power to set , there is often a fuse in the set also . Checked both ?
Is the stereo wires hooked up to the stock wires for the original stereo?
Check to see if any of the pins came loose on the molex connectors.
