I have a 1995 Bird with a 3.8 it starts then in around 15 mins or so it will die and it will not start back for a little while then it will start back up. Has a brand new battery there is no check engine light on. What can I start to check out to see what the trouble is.
Thanks
I would look at the fuel pump/filter if that isnt the issue you probably have a bad oxygen sensor.
You should check the filter first and the pump as you should get a check engine light with a sensor.
When's the last time the filter was changed? If not that, test the regulator
