·I finally got around to borrowing my friend's scanner tool this weekend
and hooked up to my '96 F-250 to see why the check engine light comes
on every now & then. I've also experienced an intermittant power loss
so I knew I'd pull something on the codes. Here's what it gave me....
KOEO Code 111
System Pass Code
No Faults Detected
During KOEO Test
Memory Code 172
H02S (sensor)
System Lean
Bank 1
Memory Code 334
EVP Sensor
Closed Valve
Above Max Voltage
Memory Code 542
Fuel Pump Secondary
Circuit Open
PCM Fuel Pump Gnd
OK, that was easy to use the scanner & pull the codes. Now-what do they
interpret to?
Is the 1st code (172) the oxy sensor? I've suspected this might be bad
for awhile, but don't want to replace unless needed (there are 2 of
them on this truck)
I don't even know what an EVP sensor is...any thoughts? What would it
make the truck do if defective?
As far as code 542 goes, I replaced the front tank fuel pump and filter
this past summer, didn't really need it but it was getting noisy so I
did it before it conked out on me. Pretty straitforward install, so
maybe this code is for the fuel pump in the rear tank?
Here are the specs on the truck....
1996 Ford F-250 4x4 Auto
5.8 L engine
212,000 miles, mostly trouble-free
Idles perfectly smooth,never a miss
When ascending a hill, *sometimes* it gives trouble-feels like you're
towing a large trailer or something like that....this does not happen
every time, though. It does not seem to be affected by the weather (New
England, so we get everything from brutal cold to blazing hot!)
Every other fill-up, I add either dry-gas or STP fuel conditioner.
Mileage *used* to be a very steady 13-15 mpg (good for the size of this
truck), but is currently around 7-10
Sorry for the lenghthy post...maybe someone can share some opinions or
ideas? Thanks!
~The Doctor
KOEO Code 111
System Pass Code
No Faults Detected
During KOEO Test
Memory Code 172
H02S (sensor)
System Lean
Bank 1
Memory Code 334
EVP Sensor
Closed Valve
Above Max Voltage
Memory Code 542
Fuel Pump Secondary
Circuit Open
PCM Fuel Pump Gnd
interpret to?
them on this truck)
5.8 L engine
ideas? Thanks!
~The Doctor
