So recently I've been getting really bad gas mileage in my '97 crown vic and
it didn't have that issue before I took out the spark plugs, And put brand
new ones(Motorcraft SP-432 AGSF32FM). I did make sure they're gapped
properly to .54mm. I also replaced the fuel filter, air filter, cleaned out the
mass air flow sensor. Put when i took off the spark plugs the wires were
stuck on there because they were never took off so i used my hands and
struggled but managed to get em off but ever since i put the new spark
plugs in an put the boots back on it hasn't gotten as good gas mileage
since. I did check to see if the spark plug wires are arching and their not
visibly arching. No cuts or tears when visible inspection. The engine has
over 270K Miles put onto it. Any Suggestions? I've took a scan tool to it as
well and here's the results. Oxygen Sensor Read at: 0.5.85V at idle, Air flow
rate MAF sensor: 7.01g/s, Short term fuel Trim (B1-S2): 99.2%, Short Term
Fuel Trim (B2-S1): -1.6%, long term trim is 0.0%.
