· Registered
I have a 1997 2.3l XLT Ranger that will not start. I replaced plugs, wires and coil packs but starting problem was prior to the tune up. Watching utube videos the next item to replace is the Ignition Control Module which I bought. The problem is that I cannot locate that part on my vehicle even though partsgeek says it fits. Any help would be apprciated. The ICU is not mounted behind the AC compressor. Not mounted behind the battery. Thanks Dale
· Super Moderator
See if this applies
Where is the ignition control module located on a 1997 Ford ranger?
where is the ignition control module located on a 1997 ford ranger
Experience: Master Auto Technician
Verified
Hello, My name is Randall. I will do my best to assist you with your question
The ignition control module is integrated within the powertrain control module and is no longer a "stand alone" component.
The PCm is located on right side of firewall , under the hood and slips through firewall and held by a couple bolts. Will have big plug going to it. It controls all ignition
· Registered
See if this applies
Verified
Thank you for sharing your knowledge conserning the ICM. I am returning that part today. Have a blessed day. Dale
· Registered
You need three things for an engine to run.. Fuel, ignition (spark) and compression.. If you were having trouble starting the engine before the tune up, (not knowing how many miles on the vehicle) I wouls suspect the timing chain is worn. Hope this helps.
