Hi, I tried replacing my clock spring because my horn and cruise control was not working. I got everything back in place and all the cables are connected. For some reason the car won’t start now, it cranks like normal but it won’t ignite and start up. Does anyone know what could be going on? I checked all the fuses, doesn’t seem to be anything wrong with them..
Moved to the correct section.
Can you hear the fuel pump prime when you turn the key? Do you have a way of checking codes?
See what version is for your car and check ALL fuse box fuses ,
Ford Crown Victoria First Generation (1992 – 1997) – fuse box diagram
Year of production: 1992, 1993, 1994, 1995, 1996, 1997
Passenger compartment fuse panel
Ford Crown Victoria -Second Generation -fuse box in passeneger compartmentFord Crown Victoria -First Generation -fuse box in passeneger compartment
Fuse/relayAmpere rating [A]Circuit protected
110Ignition (START) – Starter relay coil, DTRS
27,5Power mirrors, Mirror switch, Keypad switch, Decklid switch, Adjustable pedal switch, Driver’s door module, Cluster
35Ignition (START) – Audio mute, Police power distribution box (PDB) (Police vehicles only)
410Lighting control module (LCM) (switch illumination), Autolamp sensor
57,5Ignition (ON/ACC) – LCM
67,5LCM
710Ignition (ON/ACC) – Wiper module
810Electronic automatic temperature control (EATC) module (vehicles equipped with EATC only)
97,5Ignition (ON/ACC) – Door lock switch illumination, Heated seat switch illumination, Radio, Antenna, Electrochromatic mirror, Window relay coil, Decklid relay coil and Police ON/ACC relay coil (Police vehicles only)
1015Hazards (non-Police vehicles only)
20Hazards (Police vehicles only)
1115Ignition (ON) – Turn signals
1215Audio
1310Ignition (ON) – rear air suspension module (RASM), Cluster
1415Taxi, Adjustable pedals
1510Ignition (ON) – EATC module, A/C mode switch (vehicles equipped with manual A/C only), A/C blower relay coil
1620On-board diagnostics (OBD II)
1710Ignition (ON) – A/C mode switch (vehicles equipped with manual A/C), Blend door, Heated seat modules
1815LCM (interior lighting)
1910LCM (Left-hand low beam)
2010Ignition (ON/START) – Back-up lamps, Anti-lock brake system (ABS)
2110LCM (Right-hand low beam)
2210Ignition (ON/START) – Restraint control module (RCM), Occupant classification sensor (OCS), Passenger airbag deactivation indicator (PADI)
2315Multi-function switch (Flash-to-pass), LCM (High beams)
2410Ignition (ON/START) – Passive anti-theft system (PATS) module, Powertrain control module (PCM) relay coil, Fuel relay coil, Ignition relay coil
2515LCM (Park lamps, corner lamps, license lamps)
2610Ignition (ON/START) – Cluster, LCM, Overdrive cancel switch, Traction control switch
27Not used
287,5Brake signal, LCM (brake transmission shift interlock), ABS
292Hazard in (Police vehicles only)
302Battery saver (Police vehicles only)
312Key in (LCM)
322Hazard out (Police vehicles only)
3310Fire suppression module (if equipped) (Police vehicles only)
K101Full ISO relayWindow relay, Decklid (Police vehicles only)
Power distribution box in engine compartment
Ford Crown Victoria -Second Generation -power distribution box in engine compartmentFord Crown Victoria -First Generation -power distribution box in engine compartment
130*Ignition switch
220*Spot lights (Police vehicles only)
310*Powertrain control module (PCM) – keep alive power, Canister vent
420*Fuel relay feed
510*Rear air suspension module (RASM)
615*Alternator regulator
730*PCM relay feed
820*Driver’s door module (DDM)
915*Ignition coil relay feed
1020*Horn relay feed
1115*A/C clutch relay feed
1220*Audio (Subwoofer)
25*Police tray lamps (Police vehicles only)
1320*Instrument panel power point
1420*Stop lamp switch
1515*Foglamps (Grand Marquis only), Police accessory battery feed 1 (Police vehicles only)
1620*Heated seats (Grand Marquis only), Police accessory battery feed 2 (Police vehicles only)
1710*Commercial R/A (Crown Victoria only)
1810*Commercial R/A (Crown Victoria only)
1915*Injectors
2015*PCM
2115*Powertrain loads and sensors
2220*Police power distribution box (PDB) outputs (Police vehicles only)
2320*Police PDB outputs (Police vehicles only)
2410*Heated mirrors, Rear defrost indicator
10140**Blower relay feed
10250**Cooling fan
10350**Instrument panel (I/P) fuse box feed #1, I/P fuses 10, 12, 14, 16 and 18
10450**Instrument panel (I/P) fuse box feed #2, I/P fuses 2, 4, 6, 8, 19, 21, 23 and 25
10530**Starter relay feed
10640**Anti-lock brake system (ABS) module (Pump)
10740**Rear defroster relay feed
10820**Cigar lighter (Non-police vehicles only), Police accessory battery feed 3 (Police vehicles only)
10920**ABS module (Valves)
11030**Wiper module
11150**Police PDB or Police accessory battery feed (Police vehicles only)
11230**Air suspension compressor (non-Police vehicles only)
40**Police PDB relay feed (Police vehicles only)
11350**Police light bar or Police right-hand kick panel accessory battery feed (Police vehicles only)
11450**Police PDB or Police accessory battery feed (Police vehicles only)
11550**Rear power point or Police right-hand kick panel accessory battery feed (Police vehicles only)
116Not used
117Not used
11850**Rear power point or Police right-hand kick panel accessory battery feed (Police vehicles only)
2011⁄2 ISO relayA/C clutch
202Not used
2031⁄2 ISO relayIgnition coil
2041⁄2 ISO relayPCM
2051⁄2 ISO relayFoglamps (Grand Marquis only)
2061⁄2 ISO relayFuel
207Not used
208Not used
2091⁄2 ISO relayHorn
301Full ISO relayStarter
302Full ISO relayAir compressor (non-Police vehicles only), RUN/ACC relay (Police vehicles only)
303Full ISO relayBlower
304Full ISO relayRear defrost relay
501Not used
502DiodePCM
503Not used
60120A Circuit breakerPower seats, Lumbar, Decklid (Police vehicles only)
60220A Circuit breakerRUN/ACC relay feed – Windows, Decklid (Police vehicles only)
* Mini fuse ** Cartridge fuse
and
Ford Crown Victoria (1998 – 2002) – fuse box diagram
Year of production: 1998, 1999, 2000, 2001, 2002
Ford Crown Victoria Second Generation - fuse boxFord Crown Victoria Second Generation – fuse box
Fuse/relayAmpere rating [A]Description
115Brake Pedal Position (BPP) Switch, Multi-Function Switch, Speed Control
230Wiper Control Module, Windshield Wiper Motor
3Not used
415Lighting Control Module, Main Light Switch
515Backup Lamps, Variable Assist Power Steering (VAPS), Turn Signals, Air Suspension, Daytime Running Lamps, Electronic Day/Night Mirror, Shift Lock, EATC, Speed Chime Warning
615Speed Control, Main Light Switch, Lighting Control Module, Clock, Police Power Relay
725Powertrain Control Module (PCM) Power Diode, Ignition Coils
815Lighting Control Module, Power Mirrors, PATS Module, Keyless Entry, Clock Memory, Electronic Automatic Temperature Control (EATC), Power Windows, Police Spot Light, SecuriLock
930Blower Motor, A/C-Heater Mode Switch
1030Air Bag Module
115Radio
1218 CBLighting Control Module, Flash-to-Pass, Main Light Switch
1315Warning Lamps, Analog Cluster Gauges and Indicators, Electronic Automatic Transmission, Lighting Control Module
1420 CBWindow/Door Lock Control, Driver’s Door Module, One Touch Down
1510Anti-Lock Brakes, Instrument Cluster, Transmission Control Switch
1620Cigar Lighter
1710Rear Defrost
1810Air Bag Module
Ford Crown Victoria Second Generation - power distribution boxFord Crown Victoria Second Generation – power distribution box
120*Electric Fuel Pump Relay
230*Generator, Starter Relay, Fuses 15 and 18
325*Radio, CD Changer, Subwoofer Amplifier
430*Police Power Relay
515*Horn Relay
620*DRL Module
720 CBPower door Locks, Power Seats, Trunk Lid Release
830**Air Suspension System
950**See Fuses 5 and 9
1050**See Fuses 1, 2, 6, 7, 10, 11, 13 and Circuit Breaker 14
1140**See Fuses 4, 8, 16 and Circuit Breaker 12
1230**PCM Power Relay, PCM, Natural Gas Vehicle Module
1350**High Speed Cooling Fan Relay
1440**Rear Window Defrost Relay, Also see Fuse 17
1550**Anti-Lock Brake Module
1650**Police Option Fuse Holder
1730**Cooling Fan Relay
Relay 1Rear Defrost Relay
Relay 2Horn Relay
Relay 3Cooling Fan Relay
Relay 4Air Suspension Pump Relay, Police Power Relay
* Mini Fuses ** Maxi Fuses
