Might want to run a pressure check on the cooling system first.
I assume you have the thermostat installed with the spring on the bottom? (sorry, have to ask...seen a few that were installed upside down)
Water pump could possibly be an issue, or maybe an air bubble (uncommon due to the little pilot valve in the thermostat, but if the new one doesn't have it, then a real possibility)
These are just a few things offhand.
