Hi there,
I have a 2000 F250 power stroke and the 4x4 doesn’t work at all. No 4x4 light, no noises. I did some tests on it and I found out my gem module was bad so I replaced that but it still doesn’t work. I’m not getting any power to the shift motor either. Would that mean I have a broken wire or shorted wire? Any ideas would be greatly appreciated!
Thanks in advance
If you checked fuses and relays, you're losing power between the relay and the transfer case motor. That'd more likely be a broken wire.
