1 - 7 of 7 Posts
Hopefully a lay-up for you experts, but I'm helping a woman friend with No $$$ fix up her used Merc. A few days ago the working heater fan (worked on several speeds) stopped working. The automatic controls temp panel all lights up, but nothing happens when try make fan run any way like A/c, Vent, Defrost, etc. The interior fuse is o.k. There is a hanging (black wire AND blue white stripe wire) with an OEM connector with 90° male prongs hanging down just under glovebox from harness. I don't know these cars but am ok mechanic, sort of ok w/ electronics and wiring. ANYBODY KNOW what that wire is and could it simply be that popped off the back of the A/C Heat Controls panel???? I did a very quick prelim. feel with hands around and under and up, but no obvious female plug hanging down or looking recently "unplugged." I do have a voltmeter/amp meter and test light to check the motor power under hood (watched a few YouTubes!) but I'd love a short cut. :)))
Well, I went looking into what you're seeing. If those wires go to the HVAC equipment, there's nothing I can find saying so.I would start with a mechanic's mirror and a flashlight and see if you can find a connector to the fan housing.
Self-test ! Thank you. These are the kinds of tricks I know for Subaru and Firebird/TransAm's, but I've just never owned Fords. Thank you Gents.
What is this wire please? pass side dash and wonder if this related to blower motor not working.
51558
Anybody have a wiring diagram that might show the details for the blower motor, EATC control panel, resistor, etc. (The diagrams in Haynes book were sparse. ) Thanks !!
1 - 7 of 7 Posts
