1 - 13 of 13 Posts
I was going up a hill, car died, no warning. After checking grounds, fuses, wiring and no response from the Escape, we found a 10 amp fuse blown in the kick panel, we changed it, turned the key, heard the fuel pump, started it and it died, blowing the fuse. The fuse is #7 and the kick panel states "engine", manual states "PATS, Restraint Control Module". We have tried to find a short in the seat belts, and to reset the PATS, but it started, once, so the PATS doesn't make sense. The seat belt light has been on for a long time and I did bang the front driver's side bumper in a ditch the night before going in a driveway. Any suggestions?
Checked for any additional fuses that may also be blown in engine comp fuse box ?
Engine Compartment Fuse Box (2001-2004)
Ford Escape - fuse box diagram - engine compartmentFord Escape – fuse box diagram – engine compartment
FuseAProtected components
Horn15Horn
H/L LH15Headlamp (high/low left, High beams)
H/L RH15Headlamp (high/low right, High beams)
EEC5EEC (KPWR)
HE GO15HEGO 1,2, CMS 1,2, VMV
FUEL20Fuel pump, EEC (FPM)
HTD SEATS30Heated seats (if equipped)
INJ30EEC (VPWR), EVR, MAF, I AC, Bulkhead, HEGO fuse (as of 2003)
MAIN120Main
ALT15Alternator/ Regulator
DRL15Daytime Running Lamps (DRL) unit (feed), DRL relay
DRL215DRL module
HLEV10DHLEV
PWR 115Auxiliary power point
FOG20Foglamps, Foglamp indicator
A/C15A/C clutch
ABS25Auxiliary power point
IG MAIN40Starter
HTR40Blower motor, Blower motor relay
BTN 140JB – Accessory relay, Radio, TNS relay, Cigar lighter, Cluster, Power mirror, GEM, Accessory delay relay (as of 2003), Power windows (as of 2003), Power moonroof (as of 2003), Clock (up to 2002)
(ABS)60ABS motor, EVAC & FILL (as of 2003)
BTN 240JB – Radio, CD changer, Cluster, Dome lamps, Map lamps, Cargo lamps, Horn relay (as of 2003), GEM, Power locks (as of 2003), Speed control (as of 2003)
MAIN FAN40(2.0L)Main fan
50(3.0L
RDEF30Rear defroster
ADD FAN40(2.0L)Add fan
50(3.0L)
Relay
EEC MAIN ISOEEC relay
FUEL PUMP ISOFuel pump relay
MAIN FAN ISOLow-speed fan control relay (2.0L engine)
High-speed fan control relay I (3.0L engine)
ADD FAN ISOHigh-speed fan control relay 1 (2.0L engine)
Low-speed fan control relay (3.0L engine)
DEF RELAY ISORear defroster relay
ST RELAY ISOStarter relay
ADD FAN 2 ISOHigh-speed fan control relay 2 (3.0L engine)
Medium-speed fan control relay (2.0L engine)
FOG RELAY MICROFoglamp relay
A/C RELAY MICROA/C clutch relay
H/L RELAY MICROHeadlamp (high/low, right/left relay)
You may have a short to ground in your fuel pump.
Discussion Starter #11
We discovered that it'sthe Restraint Control Module; It actually smelled burnt. The airbag light is off too.
51806
Discussion Starter #13
Glad you found it.
Me too! I hope that this helps someone else. I found the diagram on Pintrest. We got a Chilton book from the library, searched here and I looked through websites on the Internet. Finally, one of the diagrams looked right. Cardiagn.com was the link on Pintrest. :)
1 - 13 of 13 Posts
