Hi all. Thanks for the access to discuss. My drivers door lock when actuated with the key ring remote, the door opens but not fully, the lock mechanism jumps up and down a few times and usually ends up locked again. Sometimes it will open with a 2nd push and sometimes not. Also tried the key to open the door and this didn't work either. I have stripped the door and cant see anything on the mechanism that is broken/bent or looks damaged in any way. Any ideas/help appreciated. PS the locking is set up that only the drivers door opens with the first button push and all open with the 2nd.
Check that the snipper rod is not bent (even a mild bend will do this) and that the snipper button on the widow sill is not sticking on anything.
Hi Aussieblue. Checked that today. When I stripped the door cover off and it was all free of obstruction it still pops the door open when I unlock it and the button stays down. Also the key lock doesn't work. I stripped the drive to see if it was the little drive gear but that was all still intact. Frustrated....
