$9000 - 2001 Ford Ranger MANUAL TRANSMISSION XLT w/Custom 4" Lift, Very, Very Well Maintained and Modified:
51550
• Engine short block and Cylinder Head recently rebuilt and Bored over
.050, All New Seals, Upgraded Fel Pro Perma Torque Head Gasket
• All around 4" Lift (Raised Spindles in front, Blocks and shackles in the
rear
• Custom shocks
• ALL Suspension Bushings have been replaced with New Parts
• Upgraded to Energy Suspension Polyurethane Body Mounts and
Transmission Mount
• Rebuilt Fuel Injectors
• A/C System has been totally rebuilt with all new parts
• New 32" Falken Wildpeak Tires (99% Tread left)
• Custom Powder Coated (Machine Gray) Pacer Wheels and Center Caps
• Longer Custom Wheel Lug Nuts
• Upgraded to Clear Late Model Front Turn Signals
• Upgraded to Late Model Side View Mirrors that have been Rhino Lined
• Rhino Lined Truck Bed
• New Cab Interior Carpet
• Interior Cab Seats have been Custom Reupholstered
• Rear Brake Drums Painted to color match the truck
• Custom Cat Back Exhaust with MagnaFlow Muffler and CustomSide
Exhaust
• Truck has been Professionally Aligned by a Pro Frame Shop
• New Headlights and Rear Cargo Light
• Polyurethane Tie Rod Ends
• NEW water pump, fuel pump drive belt, fan clutch, intake manifold,
coolant hoses, coolant reservoir, ignition coil/wires, front engine cover, 2
year old battery
• New Idle Air Control Valve, U-joints, Differential seal, Steering Rack
Boots, motor mounts, control arms, tie rods, sway bar end links and
bushings, timing chain and gears
• ALL Engine Sensors replaced
• Removed Air Intake Silencer
• Custom Powder Coated Valve Cover
• Modified Intake Air box for more Air Flow
• Radiator has been flushed
• Used 32" Spare Tire
• All Weather Stripping has been replaced
• Fuel System Cleaner was added to the fuel tank during every fuel fill up
• Rhino Lined Interior Door Panels
• Lucas Oils has been added to the Transmission and differential for better
lubrication
• Comes with Cargo Net, 4 Tie down ratchet straps, and a Heavy Duty
Hydraulic Jack, Two Service Manuals, fluids, Rhino Line Spray, 5 Keys
Ignition/Door Keys
• Upgraded to Ford Explorer Double Sun Visors and had reupholstered
• ALL Driver Rubber pedals have been replaced with NEW pieces
• LED Interior Lights
• Paint has been clayed to remove heavy road grime and overspray
