Hi all,
Just seeing if anyone out there can help me out.
Just changed my t5 transmission oil, as it has a small leak. All pretty straight forward, jumped in to move and it's stuck in 4 or 5 it stays in those gears,
I can still move the stick into 1st and 2nd but it stays in the higher gear even in neutral position, it's is in gear.
Is this box out time or is there a trick to it.
Any help would be greatly appreciated.
Thanks
Administrator
Hi Jimmyu. It may just be the shifter mechanism.
Just as a check have you used the correct fluid. T5s don't use gear oil like most gearboxs. They use Auto trans fluid.
Sounds like you may have popped loose the forks.
