I recently purchased a 2002 E350 Chateau with a 7.3 diesel. It is in pretty good shape although some things do not work... like the display between the two sun visors on the ceiling (see picture). This looks to be like some sort of information center which should display outside temp, time, etc. Per the picture, mine is dead.
Is there a way to repair/replace this thing... or is it best to simply leave it dead? Thanks Automotive parking light Mirror Grille Automotive lighting Hood
Could possibly have been an option pack that yours did not have even though the screen is there ? There seems to be a couple of fuses that cover the instrument cluster that may / may not be linked , no harm in checking out .
Ford F-350 (2002 – 2007) – fuse box diagram
Year of production: 2002, 2003, 2004, 2005, 2006, 2007
Passenger Compartment Fuse Box
The fuse panel is located below and to the left of the steering wheel by the brake pedal.
Ford F-250 - fuse box diagram - passenger compartmentFord F-350 – fuse box diagram – passenger compartment
NumberAmpere rating [A]Description
115Adjustable pedals
210’05-’07: Cluster
310’05-’07: Upfitter #3
420Power point – instrument panel
510’05-’07: Upfitter #4
620’02-’04: Trailer tow turn/stop relay
730High beam headlamps, Flash to pass
815’03-’04, Diesel: Back-up lamps
20’05-’07: Back-up lamps
920’03-’04: Heated mirrors
1010’02-’04: A/C clutch
1120Radio (main)
1220Cigar lighter, OBD II
135Power mirrors/switches
1415’02-’04: Daytime running lamps (DRL)
15
16
1715Exterior lamps
1820Turn lamps (flasher), Brake On-Off (BOO) lamps
1910Body security module, 4×4 module
2010’03-’04, Diesel: Fuel Injection Control Module (FICM) relay
15’05-’07: Trailer tow Electric Brake Controller (EBC)
2120’05-’07: Heated seats
2220Engine control
2320Gasoline: Engine control
Diesel: Climate control
242’03-’04: Brake pressure switch, Speed control
15’05-’07: Tow haul, Blower relay, Electronic Automatic Temperature Control
2510’02-’04: 4-Wheel Anti-lock Brake System (4WABS) module, Variable Fan Control (VFC) (’03-’04, Diesel)
2610Air bags
2715Ignition switch Run feed
2810’02-’04: EATC module, Front blower relay coil
’05-’07: Trailer tow EBC logic
2910Customer access
3015Highbeam headlamps
3115’02-’04: Clutch interlock switch (manual transmissions only), Transmission range sensor (automatic transmissions only) then to starter relay coil (all transmissions), 4×4
’05: 4×4
’06-’07: Starter relay
325Radio (start)
3315’02-’04: Front wiper
’05-’07: Cluster, 4×4, Wipers
3410Brake on-off switch (Low current)
3510Instrument cluster
3610’02-’04: PCM Memory
3715Horn
3820Trailer tow park lamps, backup lamps (’02)
3915’03-’04: Trailer tow back-up lamps
’05-’07: Heated mirrors
4020Fuel pump
4110Instrument cluster
4215Delayed accessory
4310Fog lamps
44
4510Ignition switch Run/Start feed
4610Left-hand low beam
4710Right-hand low beam
48
10130Trailer tow electric brake
10230Door locks/Body security module
10350’02-’04: Ignition switch
30’05-’07: Ignition switch
10440’03-’04: Heated backlight
10530’02, Diesel: Injector driver module
’03-’04, Diesel: Fuel heater
10630Front wiper main
10740’02-’04: Front blower motor
20’05-’07: Trailer tow battery charge
10830’05-’07: Upfitter #1
10930’02-’04: Heated seats
’05-’07: Upfitter #2
11050’02-’04: Ignition switch
11130’02-’04: 4WD/Shift on the fly
11230Left-hand power seats
11330Starter motor
11430Right-hand power seats
11520’02-’04: Trailer tow battery charge
’05-’07: Upfitter control
11630Ignition switch
60130Circuit Breaker: Delayed accessory, Power windows, Moonroof
60260’02-’04: 4WABS module
Relay
210
211’03-’04, Diesel: Back-up lamps
212
301’02-’04: Front blower motor
302Powertrain Control Module (PCM)
303’02, Diesel: Injector driver module
304’03-’04: Heated backlight
305’02-’04: Trailer tow battery charge
306Delayed accessory
307Starter
