Have a Ranger that locks the doors about 3 seconds after the engine is started..... This causes a problem if you forget when you are warming up the car. About the time you are stepping out and closing the door you hear the dang door lock behind you locking you out. How do you turn this off? I have tried the, Turn on, press unlock 3 times, turn off, 3 times and back on. This does not work
It seems that there are two more steps after what you did: turn to the on position and press the unlock button, then the lock button, then turn the key off.
If that doesn’t work it would seem that you may have an aftermarket alarm system as the factory one locks after putting it into gear not after a specific amount of time.
You getting the beep when setting ?
Put the key in the ignition and turn it to on.
Press the Unlock button three times.
Turn the ignition off.
Press the Unlock button three more times.
Turn the ignition back to on.
The horn should beep once. This tells you that you’re now in programming mode.
Press the Unlock button, then press Lock again. The horn will beep once to tell you that Auto Lock was deactivated. It will beep twice if you’re reactivating the system.
Turn the ignition back to off and listen for the horn to beep one time confirming that the programming was accepted.
