1 - 9 of 9 Posts
I purchased a used Eddie Bauer with the 5.4L, it has 58,000 miles. Yesterday it was running rough and idling rough. It rained really bad and the tempature dropped 30 degrees. I figured moisture in the gas. I put dry gas in and shortly after that I got the "service engine soon" light that blinks sometimes but stays lit. I have also been using super unleaded.
The truck is running better but still rough idling. The service engine soon light is still on.
Any ideas on where to start?
Thanks in advance,
Dan in NJ
Do you have an OBDII Scanner?? I would start there. If not go to Autozone and get a scan from them to get your problem code. Then we can go from there.
Jonny
Sounds like bad coil (cops). Go to Autozone and ask them to hook up the OBD2 scanner and get the codes.
I guess the Expy's have some issues with COPS, though my 99 Expy with 72K never blew a coild but my newer 03 Expy has already gone through 2 coils.
OK, I'll bite. What the heck is a coil (cops)??? i know what a coil is on the old distributor cars, but this sounds like something different.
U
I am having 3 of mine replaced today...darn coils...The guy at Pep-Boys said that I will need the others replaced soon...Looking at $50 per coil plus they said that they cause to plugs to go, so they are repairing that too...TOTAL $500 for tune up and 3 coils...4 more to go!!! Good luck...I guess this is not bad compared to the issues that I could have...at the end of my payments so I am guessing that other stuff will go soon...2000 Expy, I would buy another really I would...
I have used these forums extensively. Let Autozone or whomever diagnose the problem for free, beats paying for it! .....
I was getting the same errors. P0306, Spark misfires, Ignition Coil Misfires and others. I have a 2003 Exp. Eddie Bauer with 70,000 miles. I just replaced all coil packs, spark plugs and ICM (Ignition Control Module). I also had to replace a dying battery. In the past, I was replacing a plug coil here and there. It would last for a while then the same rough idle and service engine light. I am fortunate enough to have a brother in law who runs a parts distribution warehouse. But check Ebay and other online sites to save money.
After completing all the work, my engine was running really rough. I double checked everything and had loosened my PCV vacuum hose. After reconnecting everything, the engine ran a little better.
I finally corrected the rough idle after disconnecting the battery and all three connections to the Control Module on the firewall passenger side (EEC). That reset the computer. After I hooked everything back up the truck runs smooth as ever. I don't know if I made a mistake by swapping batteries while the truck was running. Shadetree Mechanics at its finest.....
Anyway, here are the codes if anyone needs them.
P0102 Mass Air Flow circuit Low Input.
P0103 Mass Air Flow circuit High Input.
P0106 EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range.
P0107 EGR/BARO Signal circuit is Less Than Self-Test minimum.
P0108 EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range.
P0112 Intake Air Temperature circuit Low Input.
P0113 Intake Air Temperature circuit High Input.
P0117 Engine Coolant Temperature circuit Low Input.
P0118 Engine Coolant Temperature circuit High Input.
P0121 In-Range Operating Throttle Position Sensor circuit failure.
P0122 Throttle Position Sensor circuit Low Input.
P0123 Throttle Position Sensor circuit High Input.
P0125 Insufficient Coolant Temperature to enter Closed Loop.
P0126 Insufficient Coolant Temperature for Stable Operation.
P0131 Upstream Heated Oxygen Sensor circuit out of range - Bank No. 1.
P0132 Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1.
P0133 Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 1.
P0135 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0136 Downstream Heated Oxygen Sensor circuit fault - Bank No. 1.
P0138 Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1.
P0140 Downstream Heated Oxygen Sensor circuit Faulty - Bank No. 1.
P0141 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0151 Upstream Heated Oxygen Sensor circuit out of range - Bank No. 2.
P0152 Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2.
P0153 Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 2.
P0155 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0156 Downstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0158 Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2.
P0160 Downstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0161 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0171 System Too Lean - Bank No. 1.
P0172 System Too Rich - Bank No. 1.
P0174 System Too Lean - Bank No. 2.
P0175 System Too Rich - Bank No. 2.
P0176 Flexible Fuel Sensor.
P0180 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0181 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0182 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0183 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0187 Engine Fuel Temperature Sensor circuit.
P0188 Engine Fuel Temperature Sensor circuit.
P0190 FRP Sensor Signal Low.
P0191 Engine Fuel Temperature Sensor circuit.
P0192 Engine Fuel Temperature Sensor circuit .
P0193 Engine Fuel Temperature Sensor circuit.
P0222 Throttle Position Sensor B circuit Input Low.
P0223 Throttle Position Sensor B circuit Input High.
P0230 Fuel Pump Primary circuit fault.
P0231 Fuel Pump Secondary circuit Low.
P0232 Fuel Pump Secondary circuit High.
P0300 Random Misfire Detected.
P0301 Misfire Detected - Cylinders 1-10.
P0302 Misfire Detected - Cylinders 1-10.
P0303 Misfire Detected - Cylinders 1-10.
P0304 Misfire Detected - Cylinders 1-10.
P0305 Misfire Detected - Cylinders 1-10.
P0306 Misfire Detected - Cylinders 1-10.
P0307 Misfire Detected - Cylinders 1-10.
P0308 Misfire Detected - Cylinders 1-10.
P0309 Misfire Detected - Cylinders 1-10.
P0310 Misfire Detected - Cylinders 1-10.
P0320 Ignition Engine Speed (PIP) Input circuit fault.
P0325 A Spark Knock Occurred - Sensor Circuitry did not respond.
P0326 Spark Knock has not been sensed.
P0330 A Spark Knock occurred - Sensor Circuitry did not respond.
P0331 Spark Knock has not been sensed.
P0340 Camshaft Position Sensor circuit fault.
P0350 Ignition Coil Primary circuit fault.
P0351 Ignition Coil A Primary circuit fault.
P0352 Ignition Coil B Primary circuit fault.
P0353 Ignition Coil C Primary circuit fault.
P0354 Ignition Coil D Primary circuit fault.
P0355 Ignition Coil Primary circuit malfunction.
P0356 Ignition Coil Primary circuit malfunction.
P0357 Ignition Coil Primary circuit malfunction.
P0358 Ignition Coil Primary circuit malfunction.
P0359 Integrated Ignition On Plug failure.
P0360 Integrated Ignition On Plug failure.
P0385 Misfire Detection Sensor circuit failure.
P0400 EGR Flow Faulty.
P0401 Insufficient EGR Flow.
P0402 EGR Flow Excessive at Idle.
P0411 Secondary Air Injection System Flow Improper.
P0412 Secondary Air Injection System Control Valve Faulty.
P0413 Secondary Air Injection Solenoid did not change when activated.
P0414 Secondary Air Injection Solenoid did not change when activated.
P0416 Secondary Air Injection Solenoid did not change when activated.
P0417 Secondary Air Injection Solenoid did not change when activated.
P0420 Catalyst System Efficiency below Limit - Bank No 1.
P0421 Catalyst System Efficiency below Limit - Bank No 1.
P0430 Catalyst System Efficiency below Limit - Bank No 2.
P0431 Catalyst System Efficiency below Limit - Bank No 2.
P0440 Evaporative Emission Purge Control Solenoid Damaged.
P0442 Leak in Evaporative System Detected.
P0443 EVAP Canister Purge Control Solenoid or Valve Faulty.
P0446 Evaporative Emission Control System Vent Control malfunction.
P0452 Fuel Tank Pressure Signal circuit Input below minimum.
P0453 Fuel Tank Pressure Signal circuit Input above maximum.
P0455 Leak or Blockage Detected in Evaporative Emission Control System.
P0460 Fuel Level Input circuit malfunction.
P0500 Vehicle Speed Sensor fault.
P0501 Vehicle Speed Sensor fault.
P0503 Poor Vehicle Speed Sensor Performance.
P0505 Idle Air Control Valve System fault.
P0552 Power Steering Pressure Sensor Shorted to Power.
P0553 Power Steering Pressure Sensor Shorted to Power.
P0602 Replace PCM.
P0603 PCM has Experienced Power Interrupt.
P0605 PCM Read Only Memory Error.
P0703 Brake On/Off Switch Input fault.
P0704 Clutch Pedal Position Switch Input circuit fault.
P0705 Transmission Range Sensor out of Self-Test Range or Shorted to Ground.
P0707 Transmission Range Sensor circuit Low Input.
P0708 Transmission Range Sensor circuit High Input.
P0712 Transmission Fluid Temperature Sensor circuit Input Low.
P0713 Transmission Fluid Temperature Sensor circuit Input High.
P0715 Turbine Shaft Speed Sensor circuit fault.
P0720 Output Shaft Speed Sensor circuit.
P0721 Output Shaft Speed Sensor circuit.
P0731 Improper Ratio for First Gear.
P0732 Improper Ratio for Second Gear.
P0733 Improper Ratio for Third Gear.
P0734 Improper Ratio for Fourth Gear.
P0735 Transmission problems.
P0736 Improper Ratio for Reverse Gear.
P0741 TCC System Improper Mechanical Performance.
P0743 Torque Converter Clutch System Electrical failure.
P0746 Electronic Pressure Control Solenoid Performance.
P0750 Shift Solenoid No. 1 circuit.
P0751 Shift Solenoid No. 1 Performance.
P0755 Shift Solenoid No. 2 circuit.
P0756 Shift Solenoid No. 2 Performance.
P0760 Shift Solenoid No. 3 circuit.
P0761 Shift Solenoid No. 3 Performance.
70765 Transmission system problems.
P0781 1 to 2 Shift Error.
P0782 2 to 3 Shift Error.
P0783 3 to 4 Shift Error.
P0784 4 to 5 Shift Error.
Update:
After replacing ICM (Ignition Control Module) in May. Plugs in June, Coils Packs in July, checking for vacuum leaks.... The truck ran great until yesterday. Now I am Idling rough. Most of the other misfires were at running speeds.
Should I have replaced everything at once?
I am really frustrated.....
Latest update - cylinder 5 misfire. By luck I went to unplug the disconnect and one wire with a crimp popped out of the disconnect. After putting the crimped terminal back into the plastic connector that plugs into the coil, I haven't had any problems and have put 15000 miles on the truck. I did pull the number 5 cyclinder plug and clean the carbon build up off because of the misfiring.
If anyone gets this rough idle problem, you should check each of the two wires that go into the plastic and rubber connector that plugs into the coil by tugging on this lightly.
This little wire saved me tons of money and headaches trying to figure out what was wrong.
If the instructions aren't clear - email me for pictures. I'll be happy to help anyone out!!
93 Ford Expedition 4.6L
GREAT info! Thanks. I'm new to the forum and taking many notes :)
Today my 03' 4.6L Expedition suddenly started idling up and down at the stop light and in park almost stalling out. The lights dim up and down and the battery light flashed on and off. I cleaned the MAS sensor and K&N filter. Still has a rough idle with up and down RPM's in park. Any sugestions? Thanks
1 - 9 of 9 Posts
6 Participants
MorningWud
