Hello,
I have a 2003 F150 Supercrew and there are a few issues that have been happening lately
First, the interior lights and rear cabin light between the 3rd brake-light do not go off.
Second, the radio works intermittently
Third, the windscreen wipers are working intermittently as well
Fourth, every once in a while, I will hear a "clicking" sound coming from the fuse box area.
Fifth, the power windows work intermittently (at the same time as the wipers)
I think it is relay #1 but I am not sure. Does this sound like a relay #1 issue?
Thanks folks.
Brent
Hello,
Thanks folks.
Brent
Re:First, the interior lights and rear cabin light between the 3rd brake-light do not go off.
Spray up in the door latches real good with PB Blaster or sometype of good cleaner a few times and this should fix it lights not going off.
the door ajar switch electrical connector.
To install, reverse the removal procedure.
If necessary, use Multi-Purpose Grease Spray F5AZ-19G209-AA or equivalent meeting Ford specification ESR-M1C159-A to lubricate the latches.
