Howdy -
My car's been making an odd 'howling' sound for a while. This week it turned into a terrible clatter coming from the accessories. Traced it to the A/C pulley, thinking the bearing went south since the sound changes when the compressor clutch engages.
Searched for this, but couldn't find anything. How do I go about removing the A/C pulley and clutch from the compressor? I have the serpentine belt off, no problems. There was a single 8mm bolt in the center of the clutch that came out without a problem. I think using a longer bolt might push this pulley and clutch off, but not sure.
Almost forgot, the compressor spins fine and A/C works ok. The pulley has a ton of free play an feels like it has sand instead of bearings when I spin it by hand ;-]
Please help!
Thank you - Mike
Discussion Starter #2
OK, I firgurd out how to get the hub and pulley off. I replaced the bearing, which then burned up in about 15 miles...
I need to replace the whole assemblly. The clutch is dragging, which I think overheated the bearing in no time flat.
I've got it arapt, but can't really see how the electromagnet part is connected. Is it pressed on, do I need to use a puller?
ANY and ALL help appreciated, please!!
FOUND IT!!
This post was for an 01 Taurus, but I checked out the compressor pics on the Autozone site and they have the same 'big posts' on the backing plate / hub. They have the same mounting arrangement of the compressor, as well as the small bolt in the center of the hub. Different PN's, probably due to internal differences.
I used to work as a tech in the R&D lab at Park Hannifin test Thermal Expansion Valves for auto AC - many cars share the exact same compressors - visteon /denso are the two I really remember. Most times there are few differences except for maybe how the variable displacement is set up, for example (it it is a VD compressor).
I figured I'd repost it here, for anyone else that has a similar problem in the future. I'm 99.9% certain it's the same for my Focus - the instructions all match what I've done.
Removal of A/C clutch:
1. Remove the A/C compressor as noted above.
µ 2. Remove the A/C clutch hub retaining bolt.
1 Hold the A/C clutch hub with the special tool.
2 Remove the bolt.
µ 3. Remove the A/C clutch (2884) and the A/C clutch hub spacer (19D648).
1 Thread an 8 x 1.25 mm bolt into the A/C clutch to force it from the compressor shaft.
2 Lift the A/C clutch and the A/C clutch hub spacer from the compressor shaft.
µ 4. Remove the pulley snap ring.
µ 5. Remove the A/C clutch pulley (2E884).
µ 6. CAUTION:
Do not use air tools. The A/C compressor clutch field coil (2987) can be easily damaged.
Remove the A/C compressor clutch field coil.
1 Note the location of the A/C compressor clutch field coil electrical connector.
2 Install the special tool on the nose opening of the A/C compressor.
3 Install the special tool.
4 Remove the A/C compressor clutch field coil.
Installation of the A/C clutch
1. Clean the A/C compressor clutch field coil and pulley bearing mounting surfaces.
µ 2. CAUTION:
Do not use air tools. The A/C compressor clutch field coil can be easily damaged.
Install the A/C compressor clutch field coil.
1 Place the A/C compressor clutch field coil on the A/C compressor with the A/C compressor clutch field coil electrical connector correctly positioned.
2 Place the special tool on the A/C compressor clutch field coil.
3 Place the special tool on the special tool.
4 Use the special tool to install the A/C compressor clutch field coil until bottomed completely against the A/C compressor.
µ 3. Note:
The A/C clutch pulley is a tight fit on the A/C compressor head; it must be correctly aligned during installation.
Install the A/C clutch pulley.
µ 4. Install the pulley snap ring with the bevel side out.
µ 5. Place one nominal thickness A/C clutch hub spacer inside the clutch hub spline opening.
µ 6. Install the A/C clutch.
µ 7. Install the A/C clutch hub retaining bolt.
2 Tighten the bolt.
µ 8. Measure and adjust the clutch air gap by removing or adding A/C clutch hub spacers.
9. Install the A/C compressor. (See above first section)
Here are the special tools:
Clutch And Clutch Field Coil
Special Service Tool(s)
2-Jaw Puller
205-D026 (D80L-1002-L) or equivalent
Installer, A/C Compressor Coil
412-065 (T89P-19623-EH)
Holding Fixture, Compressor Clutch
412-103 (T95L-19703-AH)
Remover, Differential Bearing
205-116 (T77F-4220-B1)
Installer, A/C Compressor Field Coil
412-078 (T91L-19623-CH)
Remover, A/C Compressor Field Coil
412-067 (T89P-19623-FH)
2 Participants
thefonz
