I have been having some strange issues with my escape. About six months ago I was stopped in a drive-through and the car seemed like it started to misfire. It almost died while idling in gear. I had no more symptoms for weeks afterward.
In the past few months, the problem has returned and gotten progressively worse, but it doesn't seem like a run-of-the-mill misfire. It will now idle rough, and miss randomly while driving at highway speeds, but this only happens sometimes. It seems to get worse after the engine warms up. I can start it in the driveway and drive it to work at highway speeds twenty minutes away with zero issues. If I then stop and let it idle or shut it off and restart it after it is warm, it will begin to miss. This is repeatable.
There are a couple other symptoms that may be related because they started around the same time. These are:
1.When it gets bad (missing at a higher than normal ratio) I have noticed that the battery light will flicker exactly at the same moment that it misses.
2. Several times in the past few months the gauges on the dash have reset while driving. When this happens, they do the normal startup thing, i.e. cycle from zero to max and then proceed to operate as normal. Everything else continues to operate while the gauges cycle.
Besides this the engine seems to operate normally. I have full power 99% of the time even when I stomp the gas. But occasionally it seems like multiple cylinders do not fire for a cycle, the battery light flickers, and then normal operation resumes until it happens again.
I have replaced all the plugs and checked the coils. I cleaned the battery terminals and had the battery and alternator checked; both checked out ok. I checked for vacuum leaks and found one at the EGR and fixed it. This had no effect whatsoever. To me, it seems like an obvious electrical issue. It’s like the voltage for the entire system is dropping to zero and then jumping right back up to normal like there’s an instantaneous short somewhere. At least this is my thinking since the battery light flickers when it happens. PCM? Dying alternator? Short? Any ideas?
No check engine codes.
