https://www.fleet.ford.com/products/fleet_showroom/2004fleetshowroom/2004-cvicpolice.asp#
Two new Limited Slip Axle Ratio (3.55) arrays: 730A and 770A
New optional laminated side glass for additional security and UV sunlight protection
Front Power Distribution Box available
Radio Delete now standard (speakers and wiring remain)
Air Induction System
New Rear Power Access Point provides power to trunk-mounted equipment
Spot Lamp Assembly now available on Street Appearance Package
Heated Mirrors now optional
New Optional Trunk Pack™ with Kevlar® liner
Grille Lamp, Siren and Speaker Wiring available
Personal Safety System™ with dual-stage airbags,* 2nd generation - driver and right front passenger (includes safety belt pretensioners, dual-stage airbags, & seat position sensors)
Child-proof rear door locks
Emergency interior trunk release
Side-door intrusion beams
Anti-lock braking system
Battery saver feature
Fail safe cooling system
*Always wear your safety belt and secure children in the rear seat
2 distinctive trim levels
Base
Street Appearance
4.6L SEFI V8 engine (239 hp)
4-speed automatic transmission
4-wheel disc anti-lock braking system (ABS)
Coolant recovery system
Front and rear stabilizer bars
Watt's linkage rear suspension
Speed-sensitive variable-assist power steering
Power, fold-away exterior mirrors
Radio delete
Rear power access point
Air conditioning
Rear-wheel drive
Full-frame construction
Rack-and-pinion steering
Limited-slip differential (3.55 axle)
Side driver and passenger air bags
Heated rearview mirrors
Power adjustable pedals
Locking Gas Cap
Spot lamp (driver's side or dual)
All-Speed Traction Control
Laminated side security glass
Base Police Prep Package 2 front strobe bulb and 2 rear strobe bulbs
Alternating headlight flasher
Wiring harness including the following items:
- 6 strobe cables (shielded and grounded)
- Distribution centers located in the glove box and trunk, 50-amp each fused in engine compartment. Each distribution center has 5 ground wires and can hold 6 fuses (3 battery and 3 ignitions powered)
- 50-amp battery circuit and ground available at kick panel or in trunk for radio communications
- 50-amp lightbar circuit and ground at console base or trunk (utilized by 65W Visibility Package)
- Additional 50-amp lightbar circuit available in trunk (utilized by 65W Visibility Package)
- Siren/speaker wiring pre-run to front of vehicle at available at console or trunk
- Horn/siren relay circuit available at console or trunk
- 4 extra circuits pre-run from the engine compartment to the console
- 4 extra circuits pre-run from the console to the trunk
Utilizes Rear Power Access Point and lightbar connector
Complete Police Prep Package
Includes everything in the Base Police Prep Package plus the following: Console mounting platform
Center wiring conduit
Hidden manual door lock plunger located in door frame
Trunk air circulation fan
Permanent rubber tie down strap
Dual trunk storage boxes
Rear trunk communications service tray
Street Appearance Package Color keyed retail bodyside moldings
Rear appliqué w/color keyed panels
"Crown Victoria" badge
Chrome Grille, Fascia inserts, door handle bezel & tail lamp appliqué
Wheel covers, full
Visibility Package (65W) Strobe Power Supply, 6 head with front shut off
Two (2) flashing rear deck LED lights with matching interior color housings
Visibility switch panel including 4 position slide switch and 4 rocker switches
Lighting relay center for us with visibility switch panel (controls up to 8 light bar functions)
Requires Police Prep Package, Complete
Visibility Base Package (65N) One (1) strobe power supply
Two (2) LED (high intensity) lights
One (1) switch control panel
Headlamp flasher module to interconnect directly with harness
Two (2) shielded coaxial strobe cables from trunk to grill
Roof light control center
Comfort and Convenience Group Power driver seat
Speed control
AM/FM stereo with cassette
Laminated Security Side Glass Door windows formed from a layer of polyvinyl butyral laminated between two sheets of automotive safety glass
Lamp Pre-Wire Group Package tray warning lamps pre-wire
Inner decklid lamp pre-wire
Radio Suppression Package
Provides radio suppression coverage for the following areas: Hood to body (LH/RH)
Engine to dash panel
Engine to frame
Tail pipe to frame (LH/RH)
Decklid to body (LH/RH)
Body to frame rear (LH/RH)
Spot Lamp Wiring Prep Contains wiring, bracketry and body preparation for installation of spot lamp kit purchased from manufacturer
Access hole in A-pillar
Mounting bracket in place
A-pillar moldings trimmed
Wiring and fuse located in standard fuse panel
Door edge reworked and trimmed
TRUNK PACK™ Drop-in box with a tough plastic shell made of High Density Polyethylene (HDPE)
It both aligns Police equipment laterally in the trunk and utilizes a Kevlar® lining on the fore side of the box to reduce the risk of Police equipment penetrating into the back seat or fuel tank in high-speed rear impacts
Dark Blue Pearl
Medium Brown
Gold Ash
Arizona Beige
Royal Blue
Light Blue
Ultra Blue
Light Grey
Silver Grey
Dark Toreador Red
Spruce Green
Medium Titanium
Dark Blue
Light Ice Blue
Black
Vibrant White
Silver Birch
Midnight Grey
Not all colors available on all models.
See your dealer for details.
Vehicle Links
Contact Us
Email an Associate
Fuel Efficiency
2003 Modifiers Guide
2004 Modifiers Guide
Owners Manual
Police Equipment Installation Guide
Severe Duty Maint Schedule
Specs
Towing Guide
Wiring Schematics - 2003
Wiring Schematics - 2004
Base
Street Appearance
Radio delete
Air conditioning
Rear-wheel drive
Locking Gas Cap
Wheel covers, full
Speed control
Engine to frame
Dark Blue Pearl
Medium Brown
Gold Ash
Arizona Beige
Royal Blue
Light Blue
Ultra Blue
Light Grey
Silver Grey
Dark Toreador Red
Spruce Green
Medium Titanium
Dark Blue
Light Ice Blue
Black
Vibrant White
Silver Birch
Midnight Grey
Vehicle Links
Contact Us
Email an Associate
Fuel Efficiency
Owners Manual
Specs
Towing Guide
