On my 05 ford focus i try starting it and it clicks then stops and does nothing. I start it with with a battery pack eventually but even when i do it slowly starts to die on idle or low speed and the gauges flicker but if i run high rpm it seems to do better. I replaced the battery and it worked for a week then did the same thing again. I checked how much voltage was going through the battery and it stayed at 12 volts and fell to 4 volts when a cranked it so i dont know what the problem is.
