Hello guys,
I have 2008 Ford Focus with 130k miles. the car shifts good but sometimes when shifting from 1 to 2 gear the transmission makes the car shake a bit like a hit and then the transmission light comes on with code P0731, I can still drive the car no problem while the code is on but shifting in general is rough while the light is on. I can turn the car off and on and the everything starts from the beginning again normal until the code appears again. The code also happens when using the low 1 manual gear at around 2200 rpms without shifting to second gear. I tried with overdrive off and still happens. What do you guys think the problem could be? shift solenoids? or the clutches? the fluid is red and it does not smell like it is burned.
