1 - 9 of 9 Posts
The problem I'm having after my transmission fluid change, new gasket and filter is the transmission sounds loud like a big truck taking off. It shifts fine and fluid is right where it needs to be. Any ideas ?
I hope someone has more info, I am at a loss. My guess is that the filter was not pushed up all the way up to seat and you are hearing fluid suction around the pan.
Can you post a video?
As Bajarider suggested it can be caused by the filter not being seated right and the pump sucking air.
Discussion Starter · #8 ·
So, to answer everyone at once. Yes, I took off the old O ring for the filter, and yes the new filter was seated properly. No there is no air sucking sounds. Maybe a clogged line ?
There are no lines to clog. Common sense says it has something to do with the fluid and filter change. I would recheck the work and the filter. What brand filter did you use?
1 - 9 of 9 Posts
