So I recently bought a 2010 CVPI and my turn signals arent working. Whenever I try to use them the turn signal light on the dash doesn't light up and theres no clicking. I checked the fuse and it was burnt out so I replaced it and as soon as I hit my turn signal it flashed and then the fuse blew again. Im not sure if its a flash relay, multifunction switch, or (and hopefully not) a wiring issue. All other lights work fine and so do my wipers and high beams.
Sounds like a short if it keeps blowing the fuse. You’ll have to break out the multimeter and do some wire tracing.
You could check wiring at multi function switch for damage or breaks that are shorting . According to this there are more than the one fuses related to wipers .
Ford Crown Victoria (2003 – 2013) – fuse box diagram
Year of production: 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
Passenger compartment fuse panel
2003 – 2004
Ford Crown Victoria - fuse box diagram - passenger compartmentFord Crown Victoria – fuse box diagram – passenger compartment (2003 – 2004)2005 – 2012
Ford Crown Victoria - fuse box diagram - passenger compartment (2005 - 2013)Ford Crown Victoria – fuse box diagram – passenger compartment (2005 – 2013)
Fuse/relayAmpere rating [A]Description
1152003-2004: Audio, CD changer
2005-2006: Taxi, Cluster, Lighting Control Module (Interior Lighting)
102007-2012: Ignition (START) – Starter relay coil, DTRS
252003-2004: Audio
102005-2006: Ignition (ON) – Electronic Automatic Temperature Control (EATC) module, A/C mode switch (vehicles equipped with EATC only), A/C blower relay coil
7,52007-2012: Power mirrors, Door lock switches, Mirror switch, Keypad switch, Decklid switch, DDM, Cluster
37,52003-2004: Mirrors
102005-2006:
EATC module (vehicles equipped with EATC only)
Audio (base audio system on vehicles not equipped with EATC)
52007-2012: Ignition (START) – Audio mute, Police power distribution box (PDB) (Police vehicles only)
4102003-2004: Air bags
2005-2006: Ignition (ON) – Anti-lock Brake System (ABS) module, Rear Air Suspension Module (RASM), Variable Assist Power Steering (VAPS)
2007-2012: Lighting control module (LCM) (switch illumination), Autolamp sensor
5252003-2004: Package tray and rear flasher (Police vehicle options)
102005-2006: Speed control deactivation switch, Stop signal, Brake-Transmission Shift Interlock (BTSI) (column-shift transmission)
7,52007-2012: Ignition (ON/ACC) – LCM
6152003-2004: Instrument cluster warning lamps module, Overdrive control switch, Lighting Control Module (LCM), A/C clutch, Analog cluster
102005-2006: Ignition (ON) – Cluster
7,52007-2012: LCM
7102003-2004: Driver’s Door Module (DDM), Premium radio, Start input to police PDB (Police vehicle option)
2005-2006: LCM (Park lamps, Switch illumination)
2007-2012: Ignition (ON/ACC) – Wiper module
8252003-2004: Powertrain Control Module (PCM) power relay, Coil-on plugs, Radio noise capacitor, Passive Anti-Theft System (PATS)
102005: Ignition (ON) – Rear Air Suspension Module (RASM), Variable Assist Power Steering (VAPS)
2006: LCM
2007-2012: Electronic automatic temperature control (EATC) module (vehicles equipped with EATC only)
952003-2004: Transmission range sensor
202005: LCM (Headlamps, Cornering lamps)
102006: LCM (Switch illumination)
7,52007-2012: Ignition (ON/ACC) – Door lock switch illumination, Heated seat switch illumination, Moon roof, Overhead console, Radio, Antenna, Electrochromatic mirror, Window relay coil (non-Police vehicles only), Window and decklid relay coil and Police ON/ACC relay coil (Police vehicles only)
10102003-2004: Rear window defrost, Heated mirrors
52005-2006: Ignition (ON/START) – Driver’s Door Module (DDM), Police PDB (Police vehicles only)
152007-2012: Hazards (non-Police vehicles only)
202007-2012: Hazards (Police vehicles only)
1152003-2004: Traction control indicator relay (ABS w/traction control only)
102005-2006:
Ignition (START) – ON/ACC (window) relay coil (non-Police vehicles only)
Ignition (START) – ON/ACC (window and decklid) relay coil and Police ON/ACC relay coil (Police vehicles only)
152007-2012: Ignition (ON) – Turn signals
12152003-2004: Multi-function switch for turn/hazard lamps
102005-2006: Ignition (ON/START) – Starter relay coil, DTRS
152007-2012: Audio
1352003-2004: Radio
102005-2006: Ignition (START) – Wiper module
2007-2012: Ignition (ON) – Anti-lock Brake System (ABS; 2007-2008) module, Rear Air Suspension Module (RASM), Variable Assist Power Steering (VAPS; 2007-2008), Cluster
14102003-2004: Anti-lock Brake System (ABS), Instrument Cluster
2005-2006: Ignition (ON) – BTSI (Floor-shift transmission)
152007-2012: Taxi, Adjustable pedals
15152003-2004: Speed control module, Power relay coil (Police vehicle option), LCM, Clock, EATC blower motor relay, Door lock switch illumination, Heated seat switch, Moonroof
7,52005-2006: Ignition (START) – LCM, Door lock switch illumination, Heated seat switch illumination, Moonroof, Overhead console, Electrochromatic mirror
102007-2012: Ignition (ON) – EATC module, A/C mode switch (vehicles equipped with manual A/C only), A/C blower relay coil
16152003-2004: Reversing lamps, Shift lock, DRL module, VAP Steering, Electronic day/night mirror, Overhead console, Air suspension, 2005-2006: Climate control, Heated seat module, Speed chime module (GCC only), DDM, Back-up lamps
202007-2012: Cigar lighter (2007-2008), OBD II
177,52003-2004: Wiper motor
102005-2006: Ignition (START) – Audio
2007-2012: Ignition (ON) – A/C mode switch (vehicles equipped with manual A/C), Blend door, Heated seat modules, BTSI (Floor-shift transmission)
18102003-2004: Not used
2005-2006: Ignition (ON) – A/C mode switch (manual A/C only), Blend door, DDM, Heated seat modules, Daytime Running Lamps (DRL) module
152007-2012: Lighting control module (interior lighting)
19152003-2004: Brake lamps, Brake signal for PCM, ABS and speed control module, DDM
102005-2012: Left-hand low beam, DRL
20202003-2004: Spot lamp (Police vehicle option)
102005-2012: Ignition (ON/ACC) – Back-up lamps, Anti-lock brake system (ABS; 2009-2012)
21152003-2004: LCM for park lamps and interior illumination, Autolamp/Sunload sensor
102005-2012: Right-hand low beam, DRL
22202003-2004: Speed control servo, Multi-function switch for hazard lamps, Brake on/off switch, Feed for IP fuse 19
102005-2012: Ignition (ON/ACC) – Restraint Control Module (RCM), Occupant Classification Sensor (OCS), Passenger Air bag Deactivation Indicator (PADI)
23152003-2004: EATC module, Instrument cluster, Clock, LCM, Interior lamps, Door lock switches, Door ajar and roof lamps (Taxi vehicles)
2005-2012: Multi-function switch (Flash-to-pass), LCM (High beams; 2006-2012)
24102003-2004: Left-hand low beam
2005-2012: Ignition (ON/ACC) – Passive Anti-Theft System (PATS) module, Powertrain Control Module (PCM) relay coil, Fuel relay coil, Ignition coil relay coil
25152003-2004: Cigar lighter
2005-2006: Autolamp/Sunload sensor, Power mirrors, Door lock switches (DDM), Mirror switch, Keypad switch, Decklid switch, Adjustable pedal switch, DDM
2007-2012: LCM (Park lamps, corner lamps, license lamps)
26102003-2004: Right-hand low beam
2005-2006: Ignition (ON/ACC) – Analog cluster, Warning lamp module, LCM, Overdrive cancel switch, Rear defroster relay coil
2007-2012: Ignition (ON/START) – Cluster, LCM, Overdrive cancel switch, Traction control switch
27252003-2004: LCM for cornering lamps and high beam headlamps
202005-2006: Cigar lighter, OBD II, Power point
2007-2012: Not used
28202003-2004: Power windows, DDM, Instrument panel/Door decklid release (police vehicles only)
102005-2006: Center High-Mounted Stop Lamp (CHMSL)
7,52007-2012: Brake signal, LCM (brake transmission shift interlock), ABS
29152003-2004: Not used
2005-2006: Audio
22007-2012: Hazard in (Police vehicles only)
30152003-2004: Not used
2005-2006: Stop lamps, MFS
22007-2012: Battery saver (Police vehicles only)
31152003-2004: Not used
2005-2006: Hazards (non-Police vehicles)
202005-2006: Hazards (Police vehicles)
52007-2012: Key in (LCM)
32102003-2004: Not used
2005-2006: Mirror heaters, Rear defroster switch indicator
22007-2012: Hazard out (Police vehicles only)
3310Fire suppression module (if equipped) (Police vehicles only)
Relay
K1012005-2006: Rear defroster
2007-2012: Window relay, Decklid (Police vehicles only)
Engine Compartment Fuse Box
Ford Crown Victoria - fuse box diagram - engine compartmentFord Crown Victoria – fuse box diagram – engine compartment
1252003-2004: Audio
202005: Ignition switch (Key in, RUN 1, RUN 2)
252006: Ignition switch (Key in, RUN 1, RUN 2), Hazards
302007-2012: Ignition switch
2202003-2004: Power point
252005-2006: Ignition switch (RUN/START, RUN/ACC, START)
202007-2012: Moon roof (’07-’08), Spot lights (Police vehicles only)
3202003-2004: Heated seats
102005-2012: Powertrain control module (PCM) – keep alive power, Canister vent
4102003-2004: Horns
202005-2012: Fuel relay feed
5202003-2004: Fuel pump
102005-2012: Rear Air Suspension Module (RASM), VAPS module (’05-’08)
6152003-2004: Not used
2005-2012: Alternator regulator
7202003-2004: Moonroof
302005-2012: PCM relay feed
820Driver’s Door Module (DDM)
2005-2012: Ignition coil relay feed
10202003-2004: Not used
2005-2012: Horn relay feed
11202003-2004: Daytime Running Lamps (DRL)
152005-2012: A/C clutch relay feed
12252003-2004: Not used
2005-2012:
Audio (non-Police vehicles only)
Tray lamps (Police vehicles only)
13202003-2004: Not used
2005-2012: Instrument panel power point
14202003-2004: Not used
2005-2012: Stop lamp switch
15152004: Alternator
202005-2006: Heated seats
152007-2012: Police accessory battery feed 1 (Police vehicles only)
16202003-2004: Not used
2005: Daytime Running Lamps (DRL) module
252006: Tray lamps (Police vehicles only)
202007-2012: Heated seats, Police accessory battery feed 2 (Police vehicles only)
17102003-2007: Not used
2008-2012: Commercial R/A
18102003-2007: Not used
19102003-2004: Powertrain Control Module (PCM), Fuel injectors, NGV fuel injector module
152005-2012: Injectors
20102003-2004: PCM, HEGOs
152005-2006: PCM, Mass Air Flow (MAF) sensor, IAT
2007-2012: PCM
21152003-2004: Not used
2005-2012: Powertrain loads and sensors, A/C clutch relay coil (2006)
22202003-2005: Not used
2006-2012: Police PDB outputs (Police vehicles only)
23202003-2005: Not used
2452003-2004: Not used
2005: Radio mute
2006: Not used
102007-2012: Heated mirrors, Rear defrost indicator
101302003-2004: Ignition switch, Starter motor solenoid via starter relay, IP fuses 7, 9, 12 and 14
402005-2012: Blower relay feed
10250Cooling fan (engine)
103402003-2004: Blower motor
502005: Instrument panel (I/P) fuse box feed #1, I/P fuses 23, 25, 27 and 31
2006: Instrument panel (I/P) fuse box feed #1, I/P fuses 19, 21, 23, 25 and 27
2007-2012: Instrument panel (I/P) fuse box feed #1, I/P fuses 10, 12, 14, 16 and 18
104402003-2004: Heated backlight relay
2005: Instrument panel (I/P) fuse box feed #2, I/P fuses 1, 3, 5, 7 and 9
2006: Instrument panel (I/P) fuse box feed #2, I/P fuses 1, 3, 5, 7, 8 and 9
502007-2012: Instrument panel (I/P) fuse box feed #2, I/P fuses 2, 4, 6, 8, 19, 21, 23 and 25
105302003-2004: PCM power relay or NGV module (natural gas vehicles only), Diagnostic connector, PDB 19 and 20, A/C clutch relay, Fuel pump module relay
2005-2012: Starter relay feed
10640Anti-lock brake system (ABS) module (Pump)
107402003: Crown North America (Police vehicle option)
502004: Police rear access power point (Police vehicles only)
402005-2012: Rear defroster relay feed
108502003-2004: Police rear access power point (Police vehicles only)
202005-2006:
Moonroof (non-Police vehicles only)
Spotlights (available on Police vehicles, Long Wheel Base [LWB] vehicles and commercial vehicles only)
2007-2012:
2009-2012: Cigar lighter (Non-police vehicles only),
Police accessory battery feed 3 (Police vehicles only)
109502003-2004: Light bar (Police vehicle option)
202005-2012: ABS module (Valves)
110502003-2004: Relay switch for front PDB (Police vehicle option)
302005-2012: Wiper module
111302003-2004: Power relay switch feed (Police vehicle option)
502005-2012: Police PDB or Police I/P accessory battery feed (Police vehicles only)
112502003-2004: Ignition switch feed to IP fuses 4, 6, 8, 11, 13, 15, 17, 20, 22 and 28
302005-2012: Air suspension compressor (non-Police vehicles only)
402005-2012: Police PDB relay feed (Police vehicles only)
113502003-2004: Feeds IP fuses 3, 5, 21, 23, 25, 27
2005-2012: Police light bar or Police Trunk (right-hand kick panel) accessory battery feed (Police vehicles only)
114302003-2004: VAP Steering, Air suspension compressor, Instrument cluster
115502003-2004: Ignition switch feed to IP fuses 16 and 18
2005-2012: Rear power point or Police Trunk (right-hand kick panel) accessory battery feed (Police vehicles only)
116302003-2004: Wipers
502005-2012: Police I/P accessory battery feed (Police vehicles only)
117502003-2004: B+ feed for PDB (Police vehicle option)
118202003-2004: ABS
502005-2012: Rear power point or Police Trunk (right-hand kick panel) accessory battery feed (Police vehicles only)
401
601502003-2004: Crown North America (Police vehicle option)
202005-2012: Power seats, Lumbar, Decklid (Police vehicles only)
602202003-2004: Adjustable pedals, Power seat, Locks, Decklid, Lumbar, Decklid release (Police vehicle option)
2005-2009:
RUN/ACC relay (windows) (non-police vehicles only)
RUN/ACC relay feed (windows and decklid) (police vehicles only)
2010-2012: RUN/ACC relay feed – Windows, Decklid (Police vehicles only)
Diode
5012003-2004: PCM
2005-2008: A/C clutch
5022004: A/C clutch
2005-2012: PCM
5032003-2004: Not used
2005-2007: Horn, Door latch
2008-2012: Not used
Relay
2012003-2004: Horn relay
2022003-2004: PCM relay
2005-2012: Not used
2032003-2004: Fuel pump relay
2042003-2004: A/C clutch relay
2052003-2004: Traction control switch relay
2005-2012: Not used
2062003-2004: Police vehicle relay
2005-2012: Fuel pump relay
2072005-2012: Not used
2082003-2004:
Moonroof relay
Police stop lamp relay (police vehicles only)
2005-2012: Not used
2092003-2004: Not used
3012003-2004: Blower motor relay
2005-2012: Starter solenoid relay
3022003-2004: Starter solenoid relay
2005-2012:
Air compressor relay (non-Police vehicles only)
RUN/ACC relay (Police vehicles only)
3032003-2004: Air suspension relay
2005-2012: Blower motor relay
3042003-2004: Heated backlight relay
2005-2006:
RUN/ACC relay (windows and decklid) (police vehicles only)
2007-2012: Rear defrost relay
WARNING: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market.
Crown Victoria, Ford electricity
So I recently bought a 2010 CVPI and my turn signals arent working....
Make sure they are the correct bulbs as well. If it's using a single filament where it should have a double (or vis versa) it may overload a circuit or give you odd results. If the bulbs are ok I'd start checking the grounds next, then as 85LTD noted, pull out a multimeter.
