1 - 10 of 10 Posts
After my last thread on here 2010 Ford Focus won't start (no crank) or shift out... , I replaced the shifter as suggested and replaced the starter related fuses as a precaution.
It starts, but won't shift out of park. Doing so with the override, reverse doesn't seem to work. Would an issue with the selector lever wiring harness cause that too?
Both issues came up at the same time, so it seems likely that they are connected. Section 307-05 of the workshop manual talks about checking for an open and a ground issue on the vehicle side of the harness, but doesn't talk about where it connects in much detail. It is up by the ignition switch in the steering column or is it around the junction box on the drivers side?
" reverse doesn't seem to work. " could be affected by worn linkage and not moving into the correct position . You never answered whether the brake lights were operating correctly .Is the interlock actuator operating / getting power ?
That makes sense. Apologies if I'm asking stupid questions :) The brake lights are operating correctly at this time, but the actuator doesn't allow moving the shifter lever - any movement at all requires using the override. I am not aware of any electronic issues. The workshop manual mentioned checking the fuses. I've replaced each with an equivalent new one.
If the cable is off enough that park on the shifter puts the transmission into neutral, would that keep the actuator from operating when the car is running and the brake pedal is pressed?
I'm going to take a look at the linkage on the transmission in the morning to see if anything isn't right.
An open circuit in the shift interlock electrical system can cause the shifter to become stuck in Park if the open circuit interrupts communications between the brake light switch or the ignition switch and the interlock solenoid.
Check for power at the shift interlock solenoid. With the ignition switch in the “ON” or “RUN” position and the brake pedal depressed, use an digital multi-meter to check for power at the solenoid. If power is present, the shifter interlock solenoid is bad.
If no power , have you checked fuses in all locations ?
Discussion Starter #9
I've localized the problem to the shifter cable. When I push the selector into PARK, it's still leaving the transmission in neutral. I can manually shift it into PARK using the manual lever on the drivers side of the transmission. Once I do that, the selector is able to come out of park normally. This seems to indicate that the TR sensor is involved in determining when to send power to the actuator and let it work. The workshop manual mentions the sensor as a possible cause being unable to shift from PARK, but it doesn't seem to cover this particular circumstance :)
The bushing appears to be fine, but it's hard to be certain as I was working from an awkward position with little space. When the cable is attached the manual lever, it doesn't seem to have any play if I push or pull it up and down respectively. If I try to rock the cable clip a bit, it does move (the lever stays in place) - but I wouldn't expect such motion to explain what's happening.
I'm going to see if I can get a new bushing locally (as the kit you mentioned earlier is more expensive than the replacement cable itself) and see if that helps at all. Otherwise I guess I'm looking at replacing the cable.
Ford Focus (2004 – 2010) – fuse box diagram
Year of production: 2004, 2005, 2006, 2007, 2008, 2009, 2010
Passenger Compartment Fuse Box (2004-2007)
Ford Focus - fuse box diagram - passenger compartmentFord Focus – fuse box diagram – passenger compartment
No.
A
Protected components
37​
10​
Left-hand headlight (high beam)
38​
10​
Right-hand headlight (high beam)
39​
20​
Cigar lighter, rear auxiliary power socket
40​
20​
Sliding roof
41​
20​
Door module (passenger door)
42​
7.5​
Outside rear view mirror defoggers
43​
10​
Electronic modules (battery supply)
44​
10​
OBD II (board computer diagnostics)
45​
10​
Daytime running lights
46​
10​
Instrument cluster, GEM module
47​
15​
Washer pump, heated washer nozzles
48​
20​
Low beam headlights, daytime running lights
49​
15​
Headlight switch
50​
20​
Windshield wiper
51​
15​
Fuel pump
52​
25​
Rear window defroster
53​
7.5​
Parking lamps, side lamps, tail lamps (left-hand side)
54​
7.5​
Parking lamps, side lamps, tail lamps (right-hand side)
55​
20​
Door module (driver door), central locking system
56​
20​
Keyless entry system
57​
10​
Alarm horn
58​
15​
Audio modules (battery supply)
59​
25​
Luggage compartment auxiliary power socket, trailer tow module
60​
15​
Right-hand headlight (low beam)
61​
15​
Left-hand headlight (low beam)
62​
20​
Power seat (driver side)
63​
25​
Power windows
64​
Not used
65​
10​
Airbag module
66​
7.5​
Headlight adjustment switch, low beam headlights, xenon module
67​
10​
Immobilizer module (WFS), instrument cluster (ignition supply)
68​
7.5​
Radio, instrument cluster
69​
20​
Fog light
70​
10​
Electronic modules (ignition supply)
71​
10​
72​
25​
GEM
73​
7.5​
Number plate lights
74​
15​
Stop light
75​
10​
Transmission control module, accelerator pedal
76​
7.5​
Electric parking brake (EPB)
77​
25​
Central locking relays
78​
15​
Rear window wiper
79​
15​
Folding mirror
80​
10​
Interior lights, outside rear view mirrors
81​
20​
Door module (right-hand rear)
82​
20​
Door module (left-hand rear)
83​
10​
CD-changer, rear seat entertainment (RSE)
84​
10​
Back-up light, trailer tow module
85​
10​
Cooling system
86​
20​
Seat heater
Relay
K1​
K4​
Fuel pump
K5​
Passenger Compartment Fuse Box (2007-2010)
No.
A
100​
10​
Electronic modules ignition supply​
101​
20​
Electric sunroof control module, driver’s electric seat,​
102​
10​
Heater control, steering column, diesel particulate filter, remote control receiver​
103​
10​
Lighting control battery supply​
104​
10​
Battery saver, interior lamps​
105​
25​
Heated rear window​
106​
20​
Keyless system​
107​
10​
Instrument cluster battery supply, on-board diagnostics​
108​
7.5​
Accessory to cluster (audio and navigation unit)​
109​
20​
Cigar lighter, rear auxiliary power socket​
110​
10​
Daytime running lights ignition supply to lighting control switch​
111​
15​
Fuel pump (petrol engine only)​
112​
15​
Audio modules battery supply​
113​
10​
Daytime running lights (parking lamps)​
114​
10​
Instrument cluster ignition supply, engine immobiliser​
115​
7.5​
Lighting control ignition supply​
116​
20​
Fog lamps​
117​
7.5​
Number plate lamps​
118​
20​
Door module, left-hand rear​
119​
15​
Luggage compartment auxiliary power socket​
119​
25​
Luggage compartment auxiliary power socket (vehicles with trailer tow module)​
120​
20​
Door module, right-hand rear​
121​
20​
Heated front seats​
122​
10​
Airbag module​
123​
7.5​
Heated exterior mirrors​
124​
7.5​
Parking lamps, side lamps, tail lamps (left-hand side)​
125​
7.5​
Parking lamps, side lamps, tail lamps (right-hand side)​
126​
20​
Keyless system​
127​
25​
Electric windows​
128​
Not used​
129​
20​
Windscreen wipers​
130​
Not used​
131​
15​
Rear window wiper​
132​
15​
Brake lamps​
133​
25​
Central locking relays, passenger door module​
134​
20​
Central locking, driver door module​
135​
20​
Daytime running lights​
136​
15​
Washer pump, heated washer jets​
137​
10​
Battery backup sounder​
138​
10​
Powertrain control module, accelerator pedal, automatic transmission​
139​
10​
Right-hand headlight (high beam)​
140​
10​
Left-hand headlight (high beam)​
141​
10​
Reversing lamp, electric mirrors​
142​
15​
Right-hand headlight (low beam)​
143​
15​
Left-hand headlight (low beam)​
Relay
R1​
Fuel pump
R2​
Not used
Engine Compartment Fuse Box
Ford Focus - fuse box diagram - engine compartmentFord Focus – fuse box diagram – engine compartment
No.
A
1​
60​
2004-2007: Cooling fan​
40​
2007-2010: Cooling fan
2​
80​
Power steering​
3​
60​
Passenger compartment fuse box supply 1​
4​
60​
Passenger compartment fuse box supply 2​
5​
80​
Auxiliary heater​
6​
60​
Diesel: Glow plug​
7​
30​
ABS, stability control pump​
8​
20​
ABS, stability control valves​
9​
20​
Powertrain control module​
10​
30​
Climate control blower​
11​
20​
Ignition switch​
12​
40​
Ignition relay 15l​
13​
20​
Starter solenoid​
14​
40​
Heated windscreen, right-hand side​
15​
30​
Cooling fan relay (Sigma – non A/C only)​
16​
40​
Heated windscreen, left-hand side​
17​
30​
Electric parking brake​
18​
30​
Power inverter​
19​
10​
ABS module​
20​
15​
Horn​
21​
20​
Diesel: Auxiliary heater​
22​
10​
Power steering module​
23​
30​
Headlamp washer​
24​
15​
Diesel: Pre-heating​
25​
10​
Ignition, relays​
26​
10​
2004-2007: Automatic transmission​
15​
2007-2010: Automatic transmission
10​
ST, RS: PCM continuous supply
27​
10​
Air conditioning clutch​
28​
10​
Diesel: Glow plug monitoring​
29​
10​
Dual zone climate control​
30​
3​
Powertrain control module, automatic transmission​
31​
10​
Battery sensor smart charging​
32​
10​
2004-2007:
16V+VCT: Ventilation​
10​
10​
ST, RS: Fuel injector power supply
33​
10​
Petrol: Heated oxygen sensors​
10​
Diesel: Intercooler bypass valve​
20​
ST, RS: Heated oxygen sensor
34​
10​
Petrol: Injectors, ignition transformers​
10​
2004-2007:
Diesel: Fuel pump
35​
10​
Powertrain control module, valves, solenoids​
36​
10​
Relay
R1​
Start lock (automatic transmission)
R2​
Horn
R3​
Back-up light (automatic transmission)
R4​
R5​
Diesel: Pre-heating
R6​
Main
R7​
Heated windscreen
R8​
Ignition
R9​
Headlamp washer
R10​
Heater blower
R11​
Air conditioning
R12​
Cooling fan (without air conditioning)
R13​
Starter
R14​
Power hold
Cooling fan
WARNING: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market.
Focus, Ford electricity
1 - 10 of 10 Posts
