I got into my truck to a click when I tried to start it. Knew it was my terminal connection immediately cause it happens…got out reseated the connection. I got a battery symbol on my dash and now it will turn over but not start…could it be something to do with the chip in the key not working right now, or is it a fuel pump issue…checked the fuses and relay…nothing there…no sound coming from the fuel pump…could a bad battery cause it to crank but not fire up?
The chip in the key wouldn't let it turn over if it weren't there. If you have the means of obtaining it, you can always check what fuel pressure is, but, yes, the battery can also prevent it from starting. I'd also be checking that terminal.
