Any thoughts or guidance welcome.
I have a 2012 Ford Flex SEL. A few months ago, the sunroof was inadvertently left open overnight. There was a rainstorm and the inside of the vehicle got wet
The center instrument console got wet. I let it dry over several days, eventually most of the functions came back. However, there are still buttons that don't work and the panel behaves oddly. For example, if I press a radio preset, this can change the climate settings. Everything works, but it behaves oddly and can change on its own. While I was able to "work around" most of it, the sound balance got switched to all back and I can't get it back to balanced because the twist knob does not work. I already tried disconnecting battery and resetting computer to no effect. The dealer has been reluctant to touch it until now so I may take to another dealer.
Fixable? Price?
Thanks in advance.
Honestly, I'd be looking for a replacement, but if you're so inclined, try getting the face plated off, cleaning with an electronics cleaner then WD40 to displace the moisture.
