1 - 9 of 9 Posts
Could this be the purge valve, per a couple of videos on YouTube. Stalled out after I filled the gas tank
Thanks. I ordered the purge valve. Comes in Tuesday. Looking at the old installed purge valve, there are 3 connections. One is an electrical harness. Push tab and pull out. Never seen the other 2. One is round with a thin plastic insert. The other has a blue plastic connector. Haven't tried hard yet to take them off. Don't want to break them by pushing or pulling the wrong way. Any ideas? Thanks again. R.s. logan
I've looked at all those already. A little different connector than mine. I should be able to figure it out though, thanks for helping appreciate it
I'm not sure if some had a clip that pulled out , may get a hint when new part arrives . Just have a good look round first and I'm sure you will be fine .Hope this solves your problem .
1 - 9 of 9 Posts
