1 - 12 of 12 Posts
So, I'm wanting to install LED bulbs for front and rear turn signals. Especially front as I'd like switchbacks. However, I noticed the 2014 doesn't have a flasher module, and that the signals are handled by a control module somewhere, at least to the best I was able to figure out. I saw something about using Forscan to adjust module settings to change how the "light out" function is handled for turn signals, but the only option I could find was to enable/disable the left or right signal indicator in the instrument cluster.
I'd really prefer to avoid installing resistors, as that pretty much feels like it defeats part of the point of installing LEDs. I was able to install an electronic flasher module in my Mercury inline with the LCM, and was wondering if there were any instructions on how to do that for an Exp as well. Or if there was some other method by which one could avoid hyper flashing.
Copied from another forum
Specifically for hyperflash disabling, go to the wrench tab and find the body control module as built and click on the little "play arrow" to run service procedure. THis will bring up a list of a trillion number. The ones you will be looking for are 726-13-01 0101 0000 for the front and 726-14-01 0101 0000 for the rear. change the "1s" in the bold part to "0s" and select write, a message will appear saying its the wrong code ending, click yes to overwrite. Your vehicle lights will flash and you will hear two clicking sounds and get a message to turn off ignition and turn it back on. your lights will now be fixed!
It’s not an on/off parameter, you have to change the checksum to make changes.
Discussion Starter · #6 ·
Ah, I see. Well, I've gone and ordered the OBDLink cable, so I guess I'll see what happens after it arrives.
Discussion Starter · #7 ·
Ok, got the OBDLink cable and installed Forscan on a laptop. Still doesn't look like there's a real BCM module, though...
Discussion Starter · #9 ·
I didn't see anything when looking at the GEM/SJB PIDs that seemed appropriate. Here's everything I found listed there:
Discussion Starter · #11 ·
Is this, however, what you may have been referencing previously? This is under the "computer chip" section named "Configuration and Programming" as opposed to the wrench "Service Functions" section.
1 - 12 of 12 Posts
