21 - 23 of 23 Posts
I think pre-2011 models had an actual signal flasher that could be swapped out with an electronic flasher to solve the LED issue, if I'm remembering the year correctly.
Hi
I just stumbled upon this forum. I have almost the exact same issue with my 2011 3.7L Mustang. I replaced the indicator lights with LEDs and now I cannot switch off the hyperflashing. I have the same values in the GEM/SJB Module as you do so I was wondering if you got to solve this issue? First I also thought the car had a signal flasher that just needed to be replaced with one that was "LED proof" but then I could not find a flasher anywhere and somebody told me I had to fix it with Forscan.
Discussion Starter · #22 ·
Hi
Sorry, never got this resolved. There's probably more support for figuring out the values in Forscan for Mustangs than Expeditions, so yeah, get yourself the cable, a laptop, and Forscan and you should be able to get clean access to the values you need to solve the problem. Looks like I'm left with getting something with resistors.
21 - 23 of 23 Posts
