The Ugly Dog
I have a 2014 Ranger Wildtrak 3.2 Auto with automatic headlights. I replaced the halogen headlight bulbs with LEDs. They worked fine until I used the high (main) beam for more than a few seconds then the low beam would shut off after being on about 3 seconds. Now low wont work at all, not even with the old bulbs installed. The main beam fuse is ok, I cant find a low beam fuse. The bulb plug has 1 hot and 1 ground and 1 that tests nothing, which stays the same on either high or low beam. I checked the resistance on the LED bulbs and it shows no resistance, they do work on both high and low if wired direct to the battery.
Any suggestions?
Does anyone know where I can get a wiring diagram for the lights or a service manual?
Can't seem to find anything for the Ranger in the US, but it looks like it still shares a lot with the Explorer. Not sure if that'll help with your searches.
